Pentax Lenses on Other Manufacturers Full Frame?
MarkMorb
Link Posted 19/08/2013 - 13:30
I was wondering if any of the currently available Full Frame cameras from other manufacturers would work with Pentax FA and/or DFA lenses? Are there K-Mount adapters available for Full Frame cameras?
If so has anyone out there tried it out?
Thanks,
Mark
K5 Ltd Silver, FA 31mm f1.8, FA 77mm f1.8, DFA 100mm f2.8 WR Macro, Sigma 10-20mm, Pentax (M) 50mm f1.7, Chinon (M) 50mm f1.7, Vivitar (M) 28mm f2.8
Egress UK - Record Company/Arts/Multimedia
Link Posted 19/08/2013 - 13:33
It's often a hard way to achieve things, but for what is and isn't possible then I'd suggest SRB Griturn, who make any adapter known to man and probably a few that aren't.
AF and metering are usually lost and sometimes infinity focus is too. Without an aperture ring, such as in DA lenses, then you might also find minimum aperture is the only available choice. Not good.
Algernon
Link Posted 19/08/2013 - 14:01
RiceHigh uses some Pentax lenses on a Canon body...
http://ricehigh.blogspot.com/2009/01/compatibility-list-of-pentax-full-frame.htm...
Mongoose
Link Posted 19/08/2013 - 14:21
Canon EOS DSLRs have a very short mount to image plane distance, so that would be your best bet I would think. M42 lens to EOS body is a common use case, I'm not sure if K lens to EOS body is doable but if it's not, you're basically stuck.
but it does help
Mike-P
Link Posted 19/08/2013 - 15:13
I use some of my older lenses with aperture rings on the Canon 7D (via an adapter purchased off Ebay) and they work pretty well in av mode. There is a problem when using them on a Canon FF camera though, the mirror is set further forward and it will hit the aperture lever of Pentax lenses causing it to shatter.
. My Flickr
MarkMorb
Link Posted 19/08/2013 - 15:39
Some interesting replies there, thanks folks. Sounds like it's more trouble than it's worth though!
smc
Link Posted 22/08/2013 - 22:18
Pentax lenses on NEX 7 with lens turbo adaptor - near enough full frame and a real delight with SMC-M lenses, my favourites being 28/2 and 50/1,7 on this body.
