Pentax lenses on other cameras
Yes there are adapters available to use Pentax lenses on pretty much any other system. Amazon may have them, so may SRS. You will certainly find them on E-bay.
Thanks Gwyn. I'll have a shop around. Was also hoping for some feedback of anyone who has used such an adapter.
Stan
You won't get stabilisation on your Panasonic so need to be aware of the 2x crop factor and set shutter speed accordingly.
Harry
Special features available inclued aperture control for DA type lenses, tilt control (alowing focal plane adjustment) and I think a shift version is now also available though I've not got one myself - it's a lot more expensive than the cheaper tilt models.
For M42 lenses there is also a model with a built in macro helicod - drastically increasing the focusing range - such a shame thats not been done as a PK.
The more CSC users opt for legacy glass, the more it pushes up the s/h price for us K series users.
Not sure we should be helping you out.
If the CSC lenses I'd like weren't so eyewateringly expensive I wouldn't be using the glass I have. Some of which is advertised in the classified section at knock down prices
Stan
The combination allows legacy Pentax lenses to give about the same view on micro4/3 that they do on APSC (2x crop factor*0.7x focal reducer = ~1.5x crop). Like all focal reducers it also effectively makes the lens faster & usually improves the IQ marginally. Unfortunately it doesn't get on well with the lenses designed for crop sensors though theoretically it should still give APSC type views.
tyronet2000
Plus Member
Northumberland
Stan
