Pentax Lenses for IR Photography
Posted 30/09/2016 - 23:10
I've not found a Pentax lens yet that's been a problem in that way, but I doubt that any of us have tried them all with IR in mind.
Manual lenses tend to have IR focusing marks, so that could be useful. A series lenses would be the most convenient as they will meter and stop down correctly without any hassle. However, some AF primes may also have IR marks, so they can be used manually anyway.
Posted 30/09/2016 - 23:27 - Helpful Comment
Posted 30/09/2016 - 23:58
Nice one Alan, I had seen that list and it was wrecking my head trying to remember where i had seen it.
Posted 01/10/2016 - 09:26
thanks guys
Barrie - Too Old To Die Young
Posted 02/10/2016 - 10:18
On most converted DSLR's the metering is not measuring IR at all. Metering usually being done by a separate sensor by the prism. I've never heard of a conversion adjusting the metering wavelength but no doubt it's possible. A series lenses would be the most convenient as they will meter and stop down correctly without any hassle.
Mirrorless cameras & some in liveview mode will meter from the main sensor and will be measuring the same wavelengths the image gets recorded from.
Posted 02/10/2016 - 14:30
Is there a convention to follow regarding lens hoods with IR - needed more, needed less, makes no difference.
Posted 02/10/2016 - 19:50
Always use a lenshood, regardless. As fr metering, I meant the camera would meter as designed to. With IR, we never know how much IR light is p[resent anyway, so there is a certain amount of trial and error.
Co. Durham UK
Is there anyone with experience of Pentax lenses to avoid for IR photography, or indeed any Pentax lenses they would recommend, either modern or legacy?
