Pentax lenses are weird but wonderful
The lenses have a certain indefinable quality about them, but don't necessarily have the highest resolution of all available lenses. The FA-J 75-300mm is a good example - not the sharpest of lenses, but sharp enough and having the most glorious bokeh. I picked up a new one from SRS when they were clearing the last few and use it extensively on the K-1 for flower studies and wildlife. At £100 it was a fantastic bargain.
I’ve been deliberating between a cheaper x-300mm ish lens for a bit of reach on the K1. Toss up is between this, the Sigma 70-300 APO and the FA 80-320mm... decisions!
Or I save up and buy a PLM like the one I recently sold, ha.
https://www.pentaxuser.com/forum/topic/don-t-underestimate-your--lesser--lenses-...
If you want to travel light you could do a lot worse
DA* 200mm - 99/100
D FA HD 150mm - 450 mm - 97/100
DA 18-135mm Al IF Ed DC - 93/100
DA 55-300 HD DA PLM WR - 98/100
ALL IRREPLACEABLE
Of the lenses I've used, the two that immediately come to mind as being extremely sharp while retaining fantastic rendering are the DA 35mm Limited and the Fujifilm 35mm f/1.4. Some others to a lesser degree - the Sigma and Tamron 17-50/2.8s, the DA 70mm Limited, the Auto Revuenon 50/1.4, the old Minolta 50/1.7 (though there are several versions and I don't know if all have the same formula as mine). I'm sure there are others.
Personally, I think that designing a lens for extremely high levels of sharpness tends to eliminate character, good rendering and that 3D/pixie-dust look. Striking a balance between those two things is an art that I think has declined and at which I suspect Pentax has been better at than most, though even they have caved to the market and seem to value sharpness over all other aspects of lens design (rendering, size, weight, cost etc etc).
I’d add the Flektogon 35/2.4 into the sharpness/rendering mix too.
From the old Taks you could also add the 135/3.5 as an example of a weird but wonderful lens. It's built beautifully and has top quality rendering to boot.
I have to jump on the K55 bandwagon too. It's essentially the same lens as the Takumar 55/2 that I had. There was a point where I thought it was actually better than the DA50!
That makes three of us. I’ve been tempted to grab a Tak 135/3.5. I’ve heard on numerous occasions that it’s a step up from the M135/3.5 I currently own.
7 years
The idea for the topic came because I recently had someone return an FA 20-35 because it apparently had awful softness and terrible CA. My experience of the lens shows that it's pretty sharp in the center with awful edges, improving after stopping down. There is significant CA towards the edges too. But somehow the images produced by the lens have a brilliant appeal to them. They're not for pixel peepers at all, with superb colours and microcontrast.
Does anyone have stories or experiences to share about these weird things called Pentax lenses?
If you've used lenses like the DA15, FA20-35, F24-50 and FA43 then please share your thoughts!
