Pentax F 28-80/35-80?
ocatoro
Posted 02/02/2013 - 08:27 Link
just mooching around to see what I can get hold of to play with really.
These 2 seem to be very reasonably priced. is that because theyre common? or because theyre no good?
namely the F 28-80mm f3.5-5.6 and the F SMC 35-80mm f4.5-5.6.
both £25-£40. seems a steal really.
how do they compare to the DA 18-55mm kit lens from my k100d super?
Hardgravity
Posted 02/02/2013 - 09:13 Link
Those are the old 'Standard' lenses from the film days.
They're not in the DA* league, but if you just want to play then get and enjoy.
I have copies of both and use them only on my film cameras now. The 'short' end not being short enough for my taste on a DSLR.
Cheers, HG
PPG entries.
ocatoro
Posted 02/02/2013 - 09:29 Link
ah ok, if the image quality isn't all that good, then i'll leave the cash til i can pick up something better quality.
just been reading some reviews, and it seems the F type isn't all that sharp. but the similarly priced FA versions are actually very sharp (according to review-ists). will do some more searching, maybe take a punt.
Edited by ocatoro: 02/02/2013 - 09:29
Algernon
Posted 02/02/2013 - 09:31 Link
Pentax must have thought a lot of the 28-80mm f3.5-4.5 there
are about 6 versions of it inc. 'A' Series and Takumars.
The cheaper versions seem to have been made in the same
factory as the Takumars and have a red dot/wart near the
aperture ring.
The one to go for is the SMC (original) version which at the
time of release cost £200. Quite rare because of the original
cost, but they do crop up.
See also this thread.
The 24-90mm is also a very good lens.
Edited by Algernon: 02/02/2013 - 09:33
ocatoro
Posted 02/02/2013 - 09:35 Link
haha, oddly enough i've just been reading that thread. some nice results there. i've seen an FA SMC 28-80 for cheap. that's just a slightly newer version,right?
PeterKR
Posted 02/02/2013 - 09:58 Link
My initial reaction is "Don't get these !"
Have a look at my thread "Lens weight and camera shake ?" where there was much discussion on the relative merits of the DAL 18-55 and other lenses in the 28-80 range.
I have a Sigma epsilon AF 28-70 f3.5-4.5 which I'm very pleased with.
However, the general advice was to go for the SMC F 35-70 and avoid the 35-80 and 28-80 in F or FA variants.
I now have an F 35-70 which I got for less than the sums you quoted and the Sigma only cost me £15 ! Keep looking !
Best of luck
ocatoro
Posted 02/02/2013 - 10:31 Link
thanks for the input peter. I will dig your thread out now.
andrewk
Posted 02/02/2013 - 13:04 Link
PeterKR wrote:
I have a Sigma epsilon AF 28-70 f3.5-4.5 which I'm very pleased with. However, the general advice was to go for the SMC F 35-70 and avoid the 35-80 and 28-80 in F or FA variants.
From what I've read and heard, the 35-80 is the one to avoid. I've seen it described as the worst lens Pentax ever made. I have an SMC A 35-80mm and don't use it. I wouldn't describe it as bad, but it is no better than the 18-55mm kit lens over its common focal lengths.
The SMC F 35-70mm that I have spends a lot of time on the camera. I find it quite useful as a walk around lens. It was a little sharper than the kit lens at 50mm, f/5.6 before I used the AF micro adjust function on the K30. It previously front-focussed a little (the kit lens was spot on) - haven't had time to try it out "in the wild" yet.
andrewk
Posted 02/02/2013 - 16:46 Link
Not exactly "in the wild", but I did hurriedly blag off a few shots with the SMC F 35-70mm in the garden late this afternoon to check whether the AF micro-adjustment had been a success. Most of them are shots of gates, fence panels, clothes pegs in a row and so on - not of any particular interest.
I also took one leaning over the fence, of the view from the rear of the house.
Nothing of any artistic interest. This is a 100% crop from it.
Pretty sharp, but so what? The "so what" is that this is a photo taken by a 25 year old SMC F 35-70mm zoom at 50mm, that was WIDE OPEN at f/4.5. It is sharper than the kit lens, I think. As Algernon says in another thread - "Why carry a load of primes about when one zoom will do the job?"
Edited by andrewk: 02/02/2013 - 16:58
