Pentax battery - too good to be true??
Posted 27/02/2023 - 12:57
I have seen these for the K5 and K3. It'll either be a knock off or not... is it worth the chance??? Tho they're more than likely a knock off.
To be fair everything is madev over there!!!
I have Maximafoto ones and theyre adequate for a bit less cash.
Posted 27/02/2023 - 14:28
I have DSTE ones, and they're more than adequate for a lot less cash I have Maximafoto ones and theyre adequate for a bit less cash.
~70 quid for a battery is outrageous...
Posted 27/02/2023 - 17:19
First look at the mAH 1050 the Pentax are 1860 mAH I have others which are 2800 and DSTE and all work fine. OK buying compatibles if you know they are but these ones sound like a complete rip off. I'd steer clear.
CHEERS Vic.
CHEERS Vic.
Posted 27/02/2023 - 21:12
The Maximofoto are about 15 quid'ish...
Posted 27/02/2023 - 21:24
Indeed they are. And one that I bought many years ago is still going strong while a much more recent one has packed up. Which goes to show (IMHO) that while £70 is undoubtedly far too much for a battery. beyond a certain point the less you pay the more likely you are to get a dud. The game is to find the point at which price / reliability is lowest. I'm still looking... The Maximofoto are about 15 quid'ish...
Posted 27/02/2023 - 23:55
I've got seven of them on the go - all sorts of makes. They are strictly rotated between two cameras and have been going for years. I've just withdrawn a Maximafoto that no longer holds its charge after about 7 years use. I bought two new ones last year (un branded) that are still in their boxes.
Posted 28/02/2023 - 02:33
HI
I have had good results with Kastar chargers and batteries. I like the lay-flat two-port charger and the batteries seem well-made and last without swelling. I have them for my Pentax Q, K S2, KF. Also have them for my Panasonic Zs70K.
Posted 28/02/2023 - 13:21
There's no way that's the genuine article.
I bought third party batteries for my K-3 and they started out holding around 75% of the charge of a genuine battery but after a year or so one of the two held virtually no charge at all and the other maybe 50% of the genuine one.
Genuine batteries for all manufacturers are a ridiculous price but faced with alternatives as bad as they are I hand over the cash and live worry-free.
Posted 28/02/2023 - 14:15
1050mAh is correct for this battery, but it is most unlikely to be genuine. I too have bought, and use, 3rd party batteries that are sold with no pretence about what they are - batteries that in form factor are equivalent to an OEM product, but aren't passed off as genuine or original.
I'd avoid these so called 'Pentax' ones.
Posted 28/02/2023 - 16:45
Thanks for all your replies, I'll take the advice on-board.
Posted 28/02/2023 - 20:29
One thing to be wary of with 3rd party batteries = a "tendancy" for some to swell after a year or two. If you are not observant, they can swell enough to be difficult to slide into the battery compartment - and then even more difficult (if not impossible!) to later remove!
Posted 01/03/2023 - 14:54
The Maximofoto are about 15 quid'ish...I have DSTE ones, and they're more than adequate for a lot less cash
I bought a couple of 3rd party (DSTE as it turned out) batteries when I bought my K3 in 2017. I actually only wanted a USB charger, but several chargers on Amazon were available at a price that meant that the extra batteries were almost free!
So it wasn't a conscious decision to buy DSTE -more of a "what the heck..."
I now rotate them, and I honestly see no significant difference between the 2 x DSTE and the original Pentax one.
I do realise that a sample size of 2 is statistically not really significant, but the 4 x 3rd party (dot.photo) ones for my Lumix and 3 DSTE's for my Fuji have performed sufficiently well over the years that I'll happily buy (certain) off-brand ones in the future.
And I could live with binning the odd one or two if they don't last, given that I can get 6 or 7 for the price of an OEM one
Posted 02/03/2023 - 11:19
I've bought DSTE clones of both D-Li109 & D-Li90 batteries, and they've generally had decent capacities and worked quite well - unlike some other clones where short lives &/or swelling proved problematic.
9 years
Northern Ireland
Is this "too good to be true", or is it a genuine bargain? I want a genuine Pentax product as I'm finding compatibles don't seem so good.
Any thoughts, guys?
https://www.ebay.co.uk/itm/224864158013?hash=item345af2c13d:g:EQIAAOSwxKhiH0HZ&a...
