Pentax-A 400mm F5.6 vs Tamron SP 500mm F8 Mirror
In peoples opinion, would the sharpness of the Pentax-A 400mm F5.6 be significantly better than the Tamron SP 500mm ?. If so, it will give me the ability to use smaller aperture (and I don't mind sacrificing the extra 100mm and cropping more photo's if it means more in-focus shots).
I would expect so. I have a A400 F5.6, and it's quite a bit better than my Sigma mirror lens, especially stopped down a bit.
It's also quite a lot better than a (non APO) Sigma A400 F5.6 that I also have, if that helps any.
It's big and heavy though.
A thing of beauty, certainly, but if you're after something lightweight that you can hand-hold all day, you might consider a workout programme first.
I dare say the 400mm is a lovely lens, but you'll still need sound technique to get the most from it.
Sorry if I am teaching grandma to suck eggs here.
K.
EDIT: some useful tips here.
My website
So today I have been taking a few shots of static subjects, using a tripod and flash to try and remove any possibility of it being subject movement or camera shake.
I'm now coming to the conclusion that as a fixed F8 lens at 500mm - the depth of field is increadibly shallow - much less than I expected.
But I do accept that my focus accuracy does need to improve - as again, being an F8 lens - the focus confirmation indicator in the viewfinder does not always seem to be able to lock-on - so I'm relying on my eyesight to focus.
But, as the Tamron lens is just on loan, I am in the market for a long-telephoto - and although the mirror lens is compact and light - I'm tending towards a "normal" telephoto design instead.
The advantage of the 400mm, of course, is that you can open it up wider to focus and shut it down further for more depth of field.
Best wishes, K.
My website
at 500mm:-
Jay in garden by dcweather, on Flickr
Dave
There is a load of advice on here about using long lenses especially the Tamron 500.
Algi, I've never heard of this 'front' filter, mine uses 30.5 filters behind the rear element and although I have the set of NDs, the UV has never ben off.
I didn't know the importance of the rear filter - so first thing I did this eveneng was check that there is one fitted (which thankfully there is).
But, now that I've seen examples like the picture above of the "Jay in Garden" I know that this SP500 lens is perfectly capable of getting much sharper images than I've achieved so far - so I'll be searching out all the mentioned entries on how to get the best from long lenses.
I've been using Pentax gear for years - so I can't believe I've only just joined this forum (But this is my first venture beyond a 200mm lens - hence why the focus accuracy and shallow depth of field have caught me out).
Dave
Dave
Algi, I've never heard of this 'front' filter, mine uses 30.5 filters behind the rear element and although I have the set of NDs, the UV has never been off.
MTF increases don't always translate into sharper pictures, especially on Digital which has it's own resolution limit. It might do on film, but I expect it would be un-noticeable on a lens that isn't a top performer anyway. The filters seem very rare and would probably be expensive being 82mm multi-coated so the best thing is just forget about it. There's probably a dealer somewhere that still has these in stock
13 years
Stockport,
Cheshire UK
Also - any history of poor copy A400 F5.6 lenses ?(They do seem to come up fairly often on e-bay - but I must admit that I'm a bit nervous of buying such an expensive lens from e-bay, without knowing the full history.....)
