Pentax 50-135 will not auto focus on some of my models
Check if all the electrical contacts on the lens and the cameras are clean. The AF motor contacts are the ones slightly inside the mount (not on the mount ring itself).
If that doesn't work, then you may have problems with the motor itself (you wouldn't be the first person to have this problem). Sometimes the AF motor can be jogged into functionality by moving the focusing ring manually a bit, but this is likely a temporary fix and the lens will need to be repaired for it to work well long-term.
Good luck.
For some reason my SMC Pentax DA -50-135 lens will no longer auto focus when used with my K10 or my newer K7. I was just about to take the lens to the dealer to send away and decided to haul out my two older *isD models, *isD S and *isD L. Focuses instantly without an issue.
My other Pentax lenses and Sigma lenses all work correctly with the K7 and K10. Is there a solution for this? And what would cause this. I never did use that lens on the K10 but decided just to see if it would work or not.
Hope someone has some ideas here as that lens is my primary lens for coach trips.
Daronl
almierau
Member
Saskatoon, Saskatchewan
