New Pentax Firmware updates for 6 cameras
My Website
I've tested all my lenses extensively and I can report absolutely no difference whatsoever. Focusing speed was exactly the same on both cams.
There was also no change in any AF adjustments needed. The AF settings for V1.14 were exactly the same as for V1.03
I also rechecked my other K-5 AF settings on v1.03 and that didn't need any further adjustment either. The AF tweaks I applied nearly two years ago still applied. I wouldn't have been surprised at a bit of drift.
My 'before-' and 'after-update' shots were literally sat in the same spot, same low light from shaded 60W equivalent low energy desk lamp, and the 'before' ones followed this sort of sequence:
Shoot, check, out of focus
Shoot, check, not bad
Whereas after the update it was:
Shoot, check, wow, bang on
Shoot, check, wow, another bang on
Shoot, check, er wow, bang on again
Shoot, check, oh, a bit off
Shoot, check, ah, bang on again
I can't think of any other reason for this, other than something in the firmware.
Dan
That is with limited and unscientific testing, which I know won't please you Smeggy.
It doesn't displease me
I Have to say though, I never had ...
before updating.
What version did you update from? ( forgive me if you already said )
Just updated my K5II and K5, no problems.
Ditto.
I can only assume some are updating from 1.0 which did have af issues and where fixes in version 1.02 I believe.
Concert photography
Have upgraded both ny mki and mkii from the previous firmware update and see no difference in af at all. Both bodies are set up exactly the same, tested in my lounge under 120 watts of household lighting. Mki still hunts under the table, mkii no problem as before. Above the table mk1 still hunts and eventually locks on, mkii locks straight on.
This is what I as thinking. 1.03 was the AF fix update btw
Concert photography
All roads roam to Leeds
linklink
Pentax K-5 18-55mm Tamron 70-300mm
Pentax 35mm
a few filters Manfrotto tripod and monopod Silk tripod and a bumbling approach on how to use them
linklink
Pentax 35mm
Dan
Enjoy life
Daniel Bridge
Member
Billericay, Essex
Dan
