New Pentax Firmware updates for 6 cameras
That's the first time I've done it and it's dead easy, so I say "why not?"
"He's not the Messiah, ..."
let the education continue
I suspect that Pentax have included some of the focus improvements found in the K-5 Mk11 into this firmware without advertising the fact. Why would they? If your mk1 can be improved by simply downloading and installing a file, why would you buy a newer model?
Update done and dusted...
I've too had a play around in poor low contrast light this evening and there certainly seems to be an improvement on the K5's AF lock at 300mm.
Like others I can not prove this but it is Logical in a way if the camera is to cope with the long 560mm. Not that I can afford one of those!
Today though I've had massive under exposure in my images using the 18-55mm WR with +0.7ev needing dialling in
Just a thought, check you haven't inadvertently switched to spot-metering.
Dan
switched it off and then back on again ... all is fine.
Phew.
My 560mm f5.6 is certainly locking on a lot faster with the new firmware now
. My Flickr
Have fun with the new camera.
Well my new K-5II arrived this morning already (thanks Chris) and after setting it up I loaded in the new firmware ... went through all 3 phases, switched it off and then back on ... nothing, zilch, nada, dead.
Phew.
The SD card door wasn't open when you switched it on again Mike? Mine (K5) was when I switched it back on again and for a few seconds I thought I'd bricked it (even though the update went according to plan) before realising.
Like others I'm thinking AF is a little bit better but not sure if its because someone else has told me to think it
I genuinely never have seen an issue - just followed the instructions. Am I missing something? Lead a charmed life?
Smeggypants
Member
Smegland
Can I ask why you don't upload them to a hard drive?
