New Pentax Firmware updates for 6 cameras
It casn remove minor bugs, which is probably rarely mentioned except as "improves stability", and can add useful features. I updated the Q, without which the adapter for K lenses could not be used.
It is a simple process, just follow the instructions and make sure the battery is fully charged.
or add them
let the education continue
Flipping heck - I need to find a blank card - and it's not that long since I updated it [ 9th Jan the day I got the K-30]
I only updated mine yesterday, and have had to do it again today.
Why don't you have a formatted card? Do you keep them all as is once they are full rather than off loading the photos and re-using them?
In reality, firmware updates are performance tweaks. In order to get the best performance from our computers, we (or experts on our behalf) will tweak settings within the main console, or dig deep into the registry in order to get that improved performance. These firmware updates may not necessarily provide visible improvements, but they are improvements nonetheless, so I'd advise to update in order to keep your camera performing at its peak.
A software version doesn't wear out over time like your brake pads
In reality software updates can introduce bugs as well as fixing old ones. Many have been caught out by fixing something that isn't broke.
IOW if your camera's is working fine and the update offers no functionality you require then the sensible approach is to leave well alone. You especially won't find pro's updating unless it's absolutely necessary as they have to work with tried and trusted equipment.
Software is also regularly released with known bugs as often if you wated to fix everything, nothing would ever get released.
I say the above as someone who's worked for many years testing software updates.
However life would be boring without a bit of risk taking now and again, and I am interested in StevejCoe's tests on AF for the K-5
Angela - you did say that you'd probably need a bit of practice to get the hang of doing fimware updates!!
I have just been doing some very rough and ready tests using the new firmware on a K5 MK1.
I tested out focusing speed and accuracy using DA* 16-50, DA* 50 - 135 DA 55-300 FA*31 Ltd FA35, FA50.
Tests were carried out hand held, outside in quite bright light and then again inside in a pretty dark north facing room.
For focusing accuracy I compared regular AF with results obtained using Liveview.
All lenses were used at maximum aperture.
1. My perception is that all the lenses were locked more quickly.
2. All my lenses needed some adjustment to the plus side to match the LV result.
3. DA* 16-50 and FA 50 were sharper wide open than I ever managed to previously obtain. I compared results obtained on the K10 and it really was like night and day.
4. For whatever reason the updated K5 struggles with the FA31 Ltd. There is a lot of variability, especially with shots taken indoors.
As I said this was very rough and ready. The method needs to be tightened up, along with a more detailed analysis, but so far the results look quite promising.
Regards - Steve
Was that as a result of the Update Steve. if ao did they require any adjustment, with different values, before the update?
Pentax, or JPS, can't remember which, do say updates are at user's risk and putting it right is chargeable.
The Q is the only camera I have updated, and that went fine. That was so I could use the adapter and any new lenses. The lens updates went fine as well.
The only other update done was done by JPS when they repaired my K10D.
I don't think generally we should be afraid of doing this though, but it is at our own risk if we get it wrong.
As per previous post, all the lenses needed a tweak on the plus side (an extra 3-5 points)
The FA35 and DA55-300 were previously at 0.
The others were already on the plus side.
My only real concern is that the the DA* 16-50 is now towards the maximum on the + side with little scope for further adjustment.
Everytime there is a firmware update someone notices an AF improvement.
Wishful thinking most of the time I would guess.
I take your point Mike, but I found the results significant enough to post.
IQ wise the FA50 and DA*16-50 (@ 16mm) both wide open are noticably sharper than I previously managed to obtain.
Of course this may have been down to my poor technique, but I have previously spent quite a bit of time tweaking settings for my FA50 and have always been slightly underwhelmed with the results. So much so, that I preferred to manually focus my 'A' series 1.4 when I wanted to shoot wide open.
AF speed has never been an issue for me as most of what I shoot is pretty static, but my perception is that with the exception of the FA31Ltd the lenses seemed to lock slightly quicker, particularly inside in a dimly lit room. I accept I might be wrong with this, I have no second K5, so a side by side comparison is not possible.
Regards - Steve
Pentax say it - which is why I was really worried yesterday when I had a problem with the first firmware update.
You got it
You got it
Wow
You got it
I wouldn’t rely on the SD cards as a backup or long term storage solution. There is a time limit to how long the data on them is saved without becoming corrupted. From what I’ve seen on the web suggests 5 years is typical
stevejcoe
Member
Cornwall, UK
Regards - Steve
