New Pentax Firmware updates for 6 cameras
Interesting that contrast AF ( through sensor ) has needed a FW tweak for the 'mortgage requiring' DA 560mm
Quite, I doubt there's many here that will see the benefit of this update. I'm not sure that the lens is even available yet.
Peter E Smith
My flickr Photostream
Does anyone know what the K-5's Improved stability for general performance entails? I know manufacturers always advise to update to latest firmware but sometimes is it better to leave well alone? I do wish Pentax would give more details on Firmware content.
6th Year Apprentice Pensioner
It is a simple process, just follow the instructions and make sure the battery is fully charged.
I equally doubt that the reasons given are the sole reason for the update. I would suspect/hope that improvements to the firmware found in the K5 mark 2 have been incorporated.
Regards - Steve
Maybe it will change my k5 into a K5 MkII
Hopefully it has improved stability, since as I said on the thread about the update for the mkII/s I nearly had a heart attack yesterday when updating mine, as the camera froze. Luckily it all went well after removing the battery, but I had visions of a huge repair bill for a short while.
Pentax K1-ii and MZ6
ONE UNITED Member
If you haven't got a K5ii or K%iis, is it really worth doing it, I have downloaded it but reading the website I am wondering if it is worth the bother?
A resounding YES.
Even if you haven't got the 560mm lens(has anybody?), any changes included in "2. Improved stability for general performance." will be of benefit to all owners.
Peter E Smith
A resounding YES.
A resounding DEPENDS.
I was involved for too long in software testing in my previous life and I still believe two things:
1. Version releases can include bugfixes. Some documented, some not.
2. Version releases can introduce new bugs. None documented.
If you are experiencing any odd-behaviour with your current version, or if you are in need of the new feature(s), then updating could (should) be well worthwhile. If neither, then there is an argument that you should avoid all risk by holding off.
But I'll probably still upgrade like everyone else. I might just wait a little while first though...
Mannesty
Member
Totana, Spain.
This update addresses:
1. Optimized contrast AF when using [HD PENTAX-DA 560mmF5.6ED AW] lens.
Go to this page: http://www.pentax.jp/engl...ort/download_digital.html and download the appropriate update for your camera. Follow the directions on the download page for the particulars of your camera.
Peter E Smith
