Asahi Photo Health Check Asahi Photo Health Check Asahi Photo Health Check
Need to get my K1 repaired...!!
stub
Posted 14/04/2020 - 03:23 Link
After having just received. What I consider, a very excessive quotation. From John Pye Technical. To repair the No 1 port of SD card on my K1. Mwmory card will not read. Can anyone else recommend a trusted repairer..? Plastic left in from a Sandisk SD card. I have read on, Or the U.S site here that you can poke about with some kind of cocktail stick..? But with my eyesight would probably do more harm than good... Thanks in advance ... I also realise I would have to wait until the epidemic is over..
Stuart..
mikeprotts
Posted 14/04/2020 - 10:40 Link
I've got a similar problem with my K5-II - but there is a visible pin out of line and it reports an error. I can use the camera tethered, so I know that's the only problem.
The quotes seem to be based on replacing the motherboard (which is expensive), but I'm considering dismantling myself, to see if I can replace the slot. I'm a bit nervous about tackling that, but otherwise it's a dead camera. Another option would be to find a camera that's got a mechanical failure, and get the local shop to do the work, which should be cheaper and safer.
stub
Posted 14/04/2020 - 14:52 Link
That is the annoying part.. Slot 2 is working..! And they would have to wait the part from Ricoh...
Stuart..
Posted 16/04/2020 - 00:02 Link
There was a debate a while back over the advantages (or not) of card removal vs usb cable. Removal of the card won out but here are two good reasons to use the cable!
My page on Photocrowd
jeallen01
Posted 16/04/2020 - 11:52 Link
What about trying with a narrow nozzle connected to a vacuum cleaner to suck the plastic bit out?
(I did think about suggesting a can of compressed air to blow it out - but then realised that it might go further in, and not out, and who knows what other damage that might cause?)
Another thought - would a flat & moist FF sensor swab be long enough to get in so that the plastic bit might stick to it, and then you could pull it out again??
Edited by jeallen01: 16/04/2020 - 11:55
stub
Posted 16/04/2020 - 17:18 Link
They are all good ideas. But I was wary to poke around in the slot as I have quite poor eyesight. Probably resulting in creating more damage than already at present. Hence why I was looking for a repairer. I was just put off by the price quoted at J Pye.
Stuart..
Posted 16/04/2020 - 17:54 - Helpful Comment Link
Perhaps a local repairer could do the obvious and try to remove the bit of plastic that's causing a problem, rather than simply replacing the whole slot? There is one in Liverpool - Newton Ellis and Co., 29 Cheapside, L2 2DY. 0151 236 1391
They have done some good work for me in the past and at a realistic cost.
stub
Posted 16/04/2020 - 22:17 Link
Thanks John that's perfect. I'll try and contact them tomorrow.
Stuart..
ilovesaabs
Posted 17/04/2020 - 09:27 Link
Are they still going? I remember them from my college days in the late 80's. Glad to see some remnants of old Liverpool still there.
AKA Welshwizard/PWynneJ
PRYorkshire
Posted 18/04/2020 - 17:32 Link
As an alternative could a watch repairer extract the bit of plastic. They have small tweezers and magnifying tools if the bit is accessible without dismantling the camera.
Just a thought.
Paul
Paul
stub
Posted 18/04/2020 - 21:49 Link
Thanks for the reply Paul.. That thought had crossed my mind. But I'm not 100% sure that's the whole problem. As I'm getting memory card error, even when there is no card in the slot. So I want a camera repairer to have a look at it. I will have a better chance when the Lockdown comes to a close and busineses reopen.
Stuart..
