My K1 !! will not update
Posted 04/03/2022 - 11:48
walkeja wrote:
Downloaded the latest firmware update and put in the camera and nothing happens.
what am I doing wrong?
https://www.pentaxforums.com/articles/firmware-updates/pentax-k-1-firmware-v153-...Downloaded the latest firmware update and put in the camera and nothing happens.
Did you follow the steps exactly?
Posted 04/03/2022 - 11:49
Did you hold the menu button in and then switch the camera on? The update should then download to camera. One word of warnin though, you will need the battery to be fully charged!!
Michael
Michael
Posted 04/03/2022 - 12:38
Michael
Yes I did that, I’ll try again and let you know.
Michael
Pentax K1-ii and MZ6
ONE UNITED Member
ONE UNITED Member
Posted 04/03/2022 - 12:41
Installing the K-1 firmware on a K-1ii hopefully will never work, if it did, it would likely brick your camera.
Posted 04/03/2022 - 13:13
walkeja wrote:
No, did not work, tried both SD cards, followed the correct procedure, removed the DCIM folder and no joy. I am not getting rid of the camera.
Michael
Yes I did that, I’ll try again and let you know.Did you hold the menu button in and then switch the camera on? The update should then download to camera. One word of warnin though, you will need the battery to be fully charged!!
Michael
ONE UNITED Member
ONE UNITED Member
Posted 04/03/2022 - 14:15
PM sent
Posted 04/03/2022 - 15:08
Latest firmware for the K1ii is v1.30 NOT v1.53.
Are you really are trying to brick your camera? Fortunately the updates have different file names to prevent your mistake.
Posted 06/03/2022 - 11:28
Tried again, failure.
ONE UNITED Member
ONE UNITED Member
Posted 06/03/2022 - 13:32
I was having trouble until I put the card into slot #1 ??
Barrie - Too Old To Die Young
Posted 06/03/2022 - 19:07
The firmware is downloaded in a Zip file. Did you extract it prior to attempting the update:
C.O.L.B.A.S victim
Posted 06/03/2022 - 19:24
I did not have to extract the file. The firmware is downloaded in a Zip file. Did you extract it prior to attempting the update:
"Provide a formatted SD memory card for the update software.
The download file is self-extracting. The following file is extracted. Fwdc###b.bin:"
Posted 06/03/2022 - 21:08
Yes I am well aware it's a self extracting Zip however, for the OP it's clear something did not work as he was unable to update his camera to the latest firmware. In this scenario it's worth exploring all other options.
C.O.L.B.A.S victim
Posted 06/03/2022 - 21:20
Defragged wrote:
The OP couldn't install it if he was attempting to install the K-1 update on a K-1ii with the link quoted by Benz3ne as it links to the wrong download.
Yes I am well aware it's a self extracting Zip however, for the OP it's clear something did not work as he was unable to update his camera to the latest firmware. In this scenario it's worth exploring all other options. Defragged wrote:
Posted 06/03/2022 - 21:23
Too confusing, I'm out of here
22 years
Handsacre
ONE UNITED Member
