My Favorite Focal Length for Studio Fashion
It's just so flexible, and you are just the right distance from the model, close enough to communicate, but not that close you are producing distortions or invading the models space.
I would have to agree with Benjamin, I virtually have my Tamron 17-50mm glued to my K-7, for indoors and location shoots.
Nice lens the Tamron...I have always loved Tamron stuff. I was a major junkie for the 28-75 when I was shooting Canon. Oh and let's not forget their 90 Macro...Wow!!!
Like many already have said in other discussion about this and you also says, there seems to be a distance that's comfortable to work in.
Not too far from the model or else it feels so distance and not too close because it would be too much in your face, I mean with those both the photos and for the models feeling.
The focal lengths you state I feel are just about right for most subjects but for "full body" you could imagine to go even wider like you say 30mm but for a closer head shoulders I would be more tempted to use something over 70mm to not get too close to the model.
That's just me thought and I don't have a lot off experience with portrait photography so would be interesting what your answer would be, I'm sure I can learn from it .
Doesn't it depends on how close your framing is which focal length would be the best?
Here is a sample of a close up imge shot at around 24mm i.e. 36mm in FF...
http://www.pbase.com/benjikan/image/90569372
This an easier from you to examine if you don't mind link
It has a closer framing but you still only used 45mm, right in the middle of the range you mostly used. It looks very good no doubt about that and more intimate then what you get with longer lenses.
How far did you stand away from her, around the 1,5 metre maybe?
I don't think you can use a much wider angle for such a photo because you will intrude her "space" so to say and that's what I mean.
How do your models react when they notice you're standing closer to her then most other photographers, does it work positively and how close can you get before it becomes negative?
Paris,
France
It is for this reason, that I often find myself using a wide angle zoom in non studio environments. My focal length of choice in 75% of my studio shoots is around 60-75mm i.e. 40-50mm in the 1.5 ratio APS-C sensor cameras. But I tend to shoot closer to the former. I have read on several forums that the majority of shooters tend to shoot quite a bit longer i.e. 90-120mm i.e. 60-80mm 1.5 ration APS-C sensor cameras. I find that getting in closer to the model, allows you to communicate on a different level which in my opinion is more immediate. I am also not that fond of (at least at this juncture in time) that compressed long focal length look. All of the major brands have focal lengths that fill this criteria.
I have on occasion shot shorter than the above at around 30mm (45mm) APS-C, with very pleasing results, but for this focal length I need to work in studio's with very high ceilings, as I more often than not am sitting or lying on the floor when shooting. I also need the much larger seamless when using this wider focal length or just work off of a bare studio cyclo wall.
Shooting at these shorter focal lengths most certainly have a distinctively modern edgy look about them (at least for now)...So don't be afraid to experiment with shorter than the recommended norm for fashion work. It may give you a bit of the edge to stand out from the rest of the very highly populated crowd.
Would love to get your feedback...
http://www.benjaminkanarekblog.com/gdj
