MX light seals?
Benz3ne
Posted 30/12/2019 - 20:56 Link
Recently procured a MX for a good price, but afraid the light seals are a little “past it”.
For the minute I’ve chucked in some Kodak Colorplus 200 I’ve accidentally rewound, which I managed to uncap, feed the leader and recap this morning in a dark cupboard... somehow... so therein could lie any fubared photos!
I digress, where might I find a set of light seals? Or direction for making my own (yes, I’ve read about closed cell foam but thicknesses not often discussed). Ergo, a pre-made set would be ace. Thoughts?
pschlute
Posted 30/12/2019 - 21:20 Link
There are always loads on ebay
Benz3ne
Posted 30/12/2019 - 21:51 Link
I did have a quick look but failed to find any specifically geared towards the MX, more the ME/ME Super.
Any links to them would be hugely appreciated, if possible.
Diolch.
Benz3ne
Posted 31/12/2019 - 06:36 Link
[quote:3496ace15f="pschlute"]]https://www.ebay.co.uk/itm/Premium-Light-Seal-Foam-Kit-for-Pentax-MX/19324182926...
Perfect thanks Peter. I didn’t think to stretch my eBay search to include European sellers too!
pschlute
Posted 31/12/2019 - 08:31 - Helpful Comment Link
I have not used them but at that price it is worth a go.
Look forward to seeing some MX shots when you get the camera on the go again.
Jonathan-Mac
Posted 31/12/2019 - 09:31 - Helpful Comment Link
Buy a larger sheet of foam and cut it yourself using a normal paper guillotine. It's much, much cheaper than buying pre-cut ones - buy one sheet and you have enough to replace the light seals on dozens of cameras. And if you mess it up (I've been there) then just cut some more and try again.
Something like this:
https://www.ebay.co.uk/itm/CAMERA-LIGHT-SEAL-1-5mm-THICK-OPEN-CELL-FOAM-SELF-ADH...
Benz3ne
Posted 31/12/2019 - 10:22 Link
[quote:3496ace15f="Jonathan-Mac"]Buy a larger sheet of foam and cut it yourself using a normal paper guillotine. It's much, much cheaper than buying pre-cut ones - buy one sheet and you have enough to replace the light seals on dozens of cameras. And if you mess it up (I've been there) then just cut some more and try again.
]https://www.ebay.co.uk/itm/CAMERA-LIGHT-SEAL-1-5mm-THICK-OPEN-CELL-FOAM-SELF-ADH...
That's great, thanks Jonathan. My reservations with this would be buying one that isn't thick enough for the mirror damper, for instance. Or too thick for the body seals. I've ordered the set from France as directed to by Peter above, but I might get some of this in due course, especially if I get another film camera!
Thanks for the help, both. I'm looking forward to seeing what it produces while it's paired with the M-50/1.4!
Jonathan-Mac
Posted 31/12/2019 - 18:49 - Helpful Comment Link
I use a less dense foam for mirror bumpers, they're better at absorbing the impact.
womble
Posted 01/01/2020 - 11:14 - Helpful Comment Link
Jon Goodman sells excellent pre-cut seal kits with detailed instructions. He can be contacted at [email protected] and charges very reasonable prices.
He comes highly recommended by various people on the US fora and by me.
K.
Benz3ne
Posted 01/01/2020 - 15:02 Link
K.
Amazing, thank you. I’d come across his name before but all posts were from a few years ago so I wasn’t certain whether he was still operating!
I’ll have to drop him an email and see what he comes back with! Thanks for this, Kris.
doingthebobs
Posted 01/01/2020 - 23:21 - Helpful Comment Link
Jon Goodman kits are the best I've used. He puts together the kit for the individual camera model which makes it easy to use successfully.
Tried others but he knows exactly what thicknesses and resilience the foams should be for each seal on most cameras.
May be a bit more expensive but worth it!
Bob
Benz3ne
Posted 02/01/2020 - 18:17 Link
Now ordered a set from Jon as well. I can have a look and see which stacks up as better quality, at least visually, between Jon’s and the French offering!
Thanks again to everyone for the help, as always!
