metz mecablitz 58 af-2 not firing
malross73
Posted 10/01/2017 - 12:39 Link
As the title flash is working in every way except actually firing i have tried it on my K30 as well as a K3 but having the same problem. Any suggestions much appreciated.
Malcolm
Website link
Chrism8
Posted 10/01/2017 - 12:52 Link
Daft comment, have u set a low enough shutter speed, set the dial to X or manually set something lower than 1/125th Sec.
Chris
McBrian
Posted 10/01/2017 - 12:58 Link
Might need a firmware update, the latest is V5.0 for Pentax.
Brian.
malross73
Posted 10/01/2017 - 13:20 Link
Thanks chaps yes shutter speed all correct Chris. Trying a firmware update as we speak Brian will let you know the outcome.
Malcolm
Malcolm
Website link
malross73
Posted 10/01/2017 - 16:24 Link
Metz firmware info is to remove batteries have flash turned off and connect to usb on computer. Computer is not reckonising device. Anybody else had any issues with firmware updates on metz?
Malcolm
Malcolm
Website link
scarr1
Posted 10/01/2017 - 22:40 - Helpful Comment Link
Hopefully i can help with this....the firmware update bit i mean.
Ive got a metz 50af-1, and having checked ealier (after reading this thread), it was on firmware 2.0.
Now, im not tech savvy at all....but ive got a son who is!!
So,
On the firmware update instructions, it says that the computer will recognise the device (i think its step 3.2).....mine didnt recognise it either.
Ignore that step, and go to step 4.0. Double click "FirmwareUpdateGB.exe", and follow the instructions from there.
Im now on firmware v5.0
scarr1
Posted 10/01/2017 - 22:42 - Helpful Comment Link
Holding "mode" while turning the flash on will tell you what firmware you have.
malross73
Posted 11/01/2017 - 19:11 Link
Thanks for the info Simon latest firmware now installed! flash still not bloody firing will keep trying.
Malcolm
Website link
Chrism8
Posted 11/01/2017 - 19:14 Link
Are you able to try the flash on another pentax camera, or another compatible flash of any make on yours, might just highlight where the fault may lie.
Chris
Edited by Chrism8: 11/01/2017 - 19:14
malross73
Posted 11/01/2017 - 19:19 Link
Hi Chris,
I've tried it on both my K30 and my fathers K3 no joy with both i also have a sigma flash which works fine on both cameras. Worked perfectly when last used a month or so ago, all operations seem to work just doesn't fire flash.
Malcolm
Malcolm
Website link
