Metering with K and M lenses
I wish they would un-cripple the mount, or find a workable way around the metering issues. Personally I like using an aperture ring as that is where my fingers from my left hand naturally fall. Too many years with an ME Super I guess.
Best wishes, Kris.
My website
It could make sense.
I wonder if this is related?
My website
I wonder if there there is a timing problem sometimes where the reading is taken before or after the lens is stopped down to the selected aperture.
I've seen it suggested that the meters simply aren't designed to work with f numbers above a certain value. But if that was true, I don't understand how they work with a large aperture in low light. They tend to be reliable them except in extremely low light.
This may not be exactly right, but I believe from what I've read that something like this may be happening.
Just be glad we don't use Olympus, where the use of OM lenses on current models is restricted to specific lenses and a few apertures.
here we go , halfway down the 2nd page, poster was Axl.
other thread
Primes: DA*300 F4 | DA40 F2.8 Ltd. | SMC-A 50/1.7 | Sigma 30mm F1.4 | Sirius 28/2.8
Macro : SMC-A Dental 100 macro
Zooms: 12-24 SA | 18-55 SA | 50-200 SA | 28-80 FA | 35-80 F | Vivitar 28-200
Other: Bellows | Tube sets | Vivitar 2x PK/A Tele | SEF-36PZF Flash | SBG-D1V Grip | Billingham 335
My Flickr
I was playing around with my A series 50mm f/1.4 this afternoon as a result of another thread. I took some pictures with the aperture ring set on A and at f/8 and then the same image (the camera was on a solid tripod) with the K20D in manual and the lens set to f/8. With the same notional aperture, ISO and shutter speed the image (according to the histogram) was about half a stop brighter with the lens set to f/8 than when the lens was set to A and f/8 selected via the camera body. Seemed mighty odd to me but I tried it several times and it was pretty consistent.
Did tests myself yesterday after reading about that guy about to use a K lens on his new K-m (I think).
Got a definite difference between 'A' setting and 'F8', or whatever.
Isn't this simply the difference between the distance the body and the aperture ring stop down the lens !?
The point is that the stop down of older lenses operates in a non-linear fashion, wheras the A lenses and after operate in a linear fashion electronically. If the original actuator is missing then the lens is stopped down by some other means that is non-compatible, hence the exposure drifts steadily further afield as you stop down.
What about my point that the lens does stop down to the correct position at the time of the exposure? If the camera can do that, it can also stop down correctly at the time of the light reading.
Re the focusing screen theory: I don't believe it and it makes no sense to me. I also had the problem with an *ist DS with the original screen that is said to be better in this regard than later ones.
If the reading is taken at the aperture that is used for the exposure - and I see no reason why it isn't - then the question is why is the result incorrect?
NO stopping down, and I get different results !!
1/30th, 1/20th respectively !
This seems to imply the aperture ring is not the main culprit ! It's the metering !?
Just tried taking readings at fully open (f3.5) using 'A' and '3.5' positions and pressing Green button !
Yes there's something funny going on there, but that's not the whole story because the error worsens the further the lens is stopped down.
22 years
Tyldesley,
Manchester
What I'd forgotten was that the exposure errors and difficulties with non-A lenses were always there, even with the film cameras. It was always a problem with the MZ30, 50, 60 cameras. It must be intrinsic in the way the meter coupling works on the earlier lenses. This is the linear/non-linear movement problem.
Clearly nothing can be done about it. It was probably not a problem for us in those days as many of us would have bought the MZ cameras with KAF or KAF2 mounts, both of which were compatible with K and M lenses.
