Memory Card
Posted 04/08/2023 - 14:12
Sandisk.... I use Extreme with 90mb/s and upwards transfer rate. I have them in my K3, K5ii, K-S2, K20D and a Canon 600D. I don't use any other make!
If you look on crapazon or fleabay, you'll probably get an 8 or 16 gb card pretty cheap. Refurbished ones are even cheaper.
Posted 04/08/2023 - 15:34
Up to what size and transfer speeds should I be able to use safely.
Posted 04/08/2023 - 16:31
I use 128 GB cards by SanDisk. Work great and less worry about running out of space.
Posted 04/08/2023 - 17:03
Posted 04/08/2023 - 17:19
Apart from increased capacity (and 8GB is pretty small compared with what's sold today), in what way do you think your current card needs to be better?
Posted 04/08/2023 - 17:24
Depends on the type of shooting you want to do. If it's lots of shots in a small ammount of time. Then get as fast as you can. 170 plus mb/s... if not, then 45 to 90 mb/s is fine. As for size, as big or small as you want! I have a 64 in my K3, 32 in my K5 and K20D and 16's in my astro K-S2 and 600D.Up to what size and transfer speeds should I be able to use safely.
I have had Kingston as well as other makes of card fail on me, but not Sandisk.
Posted 04/08/2023 - 18:01
I've been away from photography for a number of years, and just decided to get back into it. (hence renewing my subscription). Mainly to brings things more up to date with the more current technology.
Posted 04/08/2023 - 20:08
I use SanDisk 64 GB Extreme Pro cards using 2 which I cycle regularly through the camera, formatting each time. By using 2 smaller cards my theory is that if a card does fail then I am not faced with trying to recover a huge number of images.
Be very careful buying the cheaper SanDisk cards from the well known internet supplier. I bought what appeared to be a regular SanDisk Ultra card which then fell apart when I inserted it into the camera, luckily I was able to extract it with fine nose pliers.
Paul
Posted 04/08/2023 - 20:22
Just Ordered
SanDisk 64GB Extreme PRO SDXC Card
Posted 04/08/2023 - 23:29
Ratcatcher wrote:
Just Ordered
So now your mission, should you choose to accept it, is to fill the card with interesting photos as quickly as possible - and to post some on this forum. Enjoy! Just Ordered
Posted 05/08/2023 - 13:09
I think from memory (pardon the pun) That the card write speed on the K5 is 80mb. So its pointless wasting your hard earned, on faster spec cards. 32GB class 10. is more than enough capacity in this camera. Though I would always carry a spare one. As said previosly Sandisk are a good card. Though the market is flooded with fake Sandisk cards. Most of the main brands are good. Integral "Ultima" are my personal favourites.
Stuart..
Stuart..
Posted 05/08/2023 - 13:18
Can someone please confirm this, otherwise I’ve waisted my money
Posted 05/08/2023 - 14:53
I must say I didn't think of maximum write speed of the camera.
Would I have been better off getting this one instead.
https://www.amazon.co.uk/gp/product/B09X7G85JC/ref=ox_sc_act_title_1?smid=A3P5ROKL5A1OLE&th=1
20 years
I want to upgrade to something better.
What are your thoughts.
