M42 mount to Pentax K adapter advice please
Posted 05/09/2024 - 10:40
I recommend you push the boat out and get an genuine Pentax adapter (approx £20+) for two reasons, firstly the ones that don't sit in-mount (lip that covers the contacts) don't allow lenses to reach infinity. Secondly the cheap ones that do sit in-mount don't always ensure that the lens aligns to the top, so as you screw it in the aperture mark isn't always at the top which is annoying.
Here's an example of a genuine Pentax adapter with a M42 Tessar.
Pentax KP / HD 20-40mm
Posted 05/09/2024 - 10:45
Use the code Pentax 30120 to search for a genuine one, a quick google shows £35 ish on fleabay and £50 ish new from Wex.
Chris
Posted 05/09/2024 - 11:17
Have to agree with Rick and Chris - the Pentax genuine versions are the best.
Posted 05/09/2024 - 11:30
I think I have one surplus to requirement
Posted 05/09/2024 - 11:50
Many thanks for your help guys, invaluable as always.
If it's as recommended above I am interested geordie01
Posted 05/09/2024 - 13:18
Posted 05/09/2024 - 13:20
Posted 05/09/2024 - 22:48
That's the right one ! There is a knack to getting it in and a knack to getting it out - which is helped if you possess an intact and un bitten right thumbnail! (Biters have to improvise with some sort of metal tool).
Posted 06/09/2024 - 08:54
Getting it in is much easier if we attach the adapter to a lens and then just bayonet the whole into the camera like any K lens. To remove, unscrew the lens. Releasing the catch and letting the adapter fall out into the palm of the hand covers removal.
What we are in effect doing is temporarily converting a K bayonet camera into a screw thread one and screw thread lenses can be removed and fitted as desired.
Incidentally, the case for the Pentax adapter is a strong one. It may cost more, but it doesn't leave fragments of plating floating about like some cheaper ones do.
Hope that helps!
Hope that helps!
Posted 06/09/2024 - 09:46
I use the removal tool I got with a cheap adaptor works great.
Posted 06/09/2024 - 14:36
Another vote here for using the genuine ones. The first time I tried a third-party one, in a camera shop, it got stuck on my K200D and their technician had to remove it. That kept me away from M42 lenses for a couple of years before I got a genuine one which worked without problems. I have several now, all bought used, and I don't think any cost me more than 20 quid.
The nail on the left forefinger un-clips it to remove it from the camera, holding the camera in the right hand.
8 years
As I'm still relatively new to the Pentax digital world, I would be grateful for any informed advice any member has to offer on the purchase of an appropriate adapter.
