Looking for a general use quick lens with 'macro' capability
Posted 31/08/2015 - 11:14 - Helpful Comment
The 18-135mm WR lens focuses close, though not as close as your macro lens, has weather resistance, gives excellent image quality. All lenses should be sharp wide open, but of course some resolve more detail than others and some have a better edge performance than others. As a general purpose lens the 18-135mm should serve very well.
Posted 31/08/2015 - 11:19
johnriley wrote:
The 18-135mm WR lens focuses close, though not as close as your macro lens, has weather resistance, gives excellent image quality..
Thanks. I hadn't considered it because of the aperture range- f/3.5-5.6. The 18-135mm WR lens focuses close, though not as close as your macro lens, has weather resistance, gives excellent image quality..
I'm used to quick lenses (Tamron 17-50 f2.8, Sigma 30mm f1.4, Pentax 100mm f2.8, Sigma 70-200 f2.. The focal length is obviously great on it. In an ideal world I'd be able to try it (and other lenses) out for an afternoon and then decide.
I could try out my 70-200mm lens and keep it within the f/3.5-5.6 aperture range.
Cheers.
Posted 31/08/2015 - 11:27
The older version Sigma 17-70mm F2.8-4.5 DC Macro is also a very worthy consideration. F2.8 at its widest, focuses to under 8 inches, well built and still available used at a good price. link
Good luck.
Good luck.
C.O.L.B.A.S victim
Posted 31/08/2015 - 11:32
The short as is that it won't. By definition a true macro lens gives a 1:1 ratio, like your Pentax 100mm macro. Other zoom lenses with a 'macro' setting generally don't and although you can get close-up it's not as close. I have the 100mm macro as well, and if you want macro then that or similar macro primes are best. I also have an 18-80 zoom with 'macro' but that doesn't come close (literally and image quality) and because of it's weight stays on the shelf. If you don't want to lose the macro quality the alternative might be a shorter focus macro lens, say 35 or 50mm. If you still want the zoom capability you might look at the new Pentax DA 18-50mm which is very compact; that means you would still have two lenses but would be less bulky than your present set-up.
Having said that if your 100mm macro doesn't get used much then you probably wouldn't want to splash out on another specialist lens.
Posted 31/08/2015 - 11:52
I normally end up using my compact (Panasonic LX7) for macro. If you're out and about it's bother to change the lens for a close up shot. Unless you go out with macro in mind; which I don't. I just think it'd be nice to have as good close up ability as possible on my everyday lens. The short as is that it won't. By definition a true macro lens gives a 1:1 ratio, like your Pentax 100mm macro. Other zoom lenses with a 'macro' setting generally don't and although you can get close-up it's not as close. I have the 100mm macro as well, and if you want macro then that or similar macro primes are best. I also have an 18-80 zoom with 'macro' but that doesn't come close (literally and image quality) and because of it's weight stays on the shelf. If you don't want to lose the macro quality the alternative might be a shorter focus macro lens, say 35 or 50mm. If you still want the zoom capability you might look at the new Pentax DA 18-50mm which is very compact; that means you would still have two lenses but would be less bulky than your present set-up.
On a side note I often wonder how much more bulk it'd add onto a lens to make it macro or very close to....
Posted 31/08/2015 - 12:51
I would echo the recommendation for a Sigma 17-70 F2.8-4 HSM OS lens, the close focussing is pretty good and fine for everyday use on flowers, butterflies etc. No, it's not true macro but it's a good compromise. In addition, the lens itself is superb as a walkabout and is my most used lens. Good for landscapes, good for portraits, there's not much this lens can't do.
Posted 31/08/2015 - 14:03
I agree with John.The 18-135mm WR lens focuses close, though not as close as your macro lens, has weather resistance, gives excellent image quality. All lenses should be sharp wide open, but of course some resolve more detail than others and some have a better edge performance than others. As a general purpose lens the 18-135mm should serve very well.
If you rarely use macro, you might consider carrying a close-up lens to clip onto your everyday lens for occasional use, such as a Raynox 250. I don't have one, but you can see lots of examples of its results, e.g. https://www.flickr.com/search/?text=pentax%20raynox
Cheers.
Philip
Posted 31/08/2015 - 23:24
What David said. I have the Sigma 17-70 F2.8-4.5 version and love it.
Posted 31/08/2015 - 23:30
I don't know anything about today's fancy lenses because I can't afford them so here's a cheapo list that you can buy off Ebay for under £20 and try them out anyway.
I'll bet you end up keeping them.
you might try a Pentax A series 35 - 70mm zoom. It's a great carry round lens with good IQ albeit not that fast at f3.5 - 4.5 but ISO 400 can deal with that if need be.
Pentacon's M42 fit f3.5 30mm is another really good one - razor sharp and capable of severe crops that you'd think were taken by a dedicated close up lens (the similar 29mm is a dud by comparison so leave it alone).
Also, If you sell your 100mm macro you will struggle find another so I'd hang onto it.
Posted 31/08/2015 - 23:54
Cheers.
I have often used the 18-135 with a decent Hoya No 1 C/u lens with quite reasonable results in my last job.
Philip
Cheers.
Philip
I have a Tamron SP AF 17-50mm F/2.8 XR Di II LD Aspherical lens and also a Pentax 100mm 1:1 macro lens. The macro lens doesn't get used much, I was thinking of replacing both with 1 if possible.
I know there's some lens (17-70 f2.8-f4, 28-75 etc.) that say 'macro' but how much better at closeups would one be than my current lens?
Can anyone recommend some options to replace my two lenses please?
I don't pixel peep so IQ isn't a deal breaker, obviously I'd like a sharp lens wide open but I'm open to all options (losing the constant f2.8, losing the 17mm focal length etc.); at the moment I'm just looking for options (and prices please, will probably go 2nd hand).
Thanks in advance,
Pa.
Pa
