Long exposure without an ND filter
Pentaxophile
Posted 14/05/2018 - 09:42 Link
I came across this technique while looking for a workaround to use with my Samyang 14mm. I can't afford a 150mm filter system, so this looks like it might be worth playing with.
It's a technique that's also used for star trails. You take multiple exposures and blend them. Say you have 10 x 3-second exposures, that's a 30 second long exposure shot after blending. If your camera has multiple exposure mode, it can all be done in camera. If you want to go beyond ten shots, you could use the intervalometer and process them yourself.
https://www.slrlounge.com/long-exposure-photography-without-using-a-filter/
Wouldn't it be nice if this could be automated as a mode in your camera? You could tell it the length of exposure you wanted, and then it could calculate and fire off the number of shots required and process the result in-camera for you.
JohnX
Posted 14/05/2018 - 12:06 Link
Interesting. Whilst my K5II will take up to 9 shots, my K3II will take up to 2000 (at least, that's what the manual states).
So, with a 30 sec exposure per frame, that's.......mind boggling!!
Pentaxophile
Posted 14/05/2018 - 14:27 Link
2000 shots in multiple exposure mode?
swarf
Posted 14/05/2018 - 15:01 Link
Karlo
That should work in many circumstances particularly where you have a moving subject, or at least part of the subject is moving. I'm not sure that it would work so well, or pehaps as intuatively, where the main part of the subject is static and it's the camera that is moving.
Nevertheless, I'll give it a try. It might be that you get a different effect. As regards the number of shots, I have enough trouble working with 9, I fear that any more may result in permanent brain fade!
Phil
My Flikr Page link
JohnX
Posted 14/05/2018 - 15:11 - Helpful Comment Link
Surprising to me too!
Manual states;
5 Specify [Number of Shots}.
Select from 2 to 2000 times.
Haven't check the camera software. Could always be a typo, but he same upper limit is shown under "Interval Shooting" and "Interval Composite" too.
alfpics
Posted 14/05/2018 - 15:35 - Helpful Comment Link
It does work - I took one with the K3ii last year. Can't remember how many shots I took, but used the 'average' mode;
A PS - I think it was thirty or so.
Andy
Edited by alfpics: 14/05/2018 - 15:36
RobL
Posted 14/05/2018 - 18:47 - Helpful Comment Link
It can in the K1! It’s called interval composite mode where you set the number of exposures and their frequency and it blends in camera.
Pentaxophile
Posted 14/05/2018 - 21:59 Link
Ah, yes! Nice one Pentax, another cool feature that no-one else has thought of (afaik).
https://www.pentaxuser.com/forum/topic/interval-composite-shooting-57103
