Lens storage - silica gel
Posted 08/11/2017 - 19:01 - Helpful Comment
You could just put a dust cloth over the lenses. It might actually help if the cloth (cotton ? ) also absorbs moisture keeping the lenses even drier.
I've never heard of any problems with silica gel. It does only absorb moisture from air that is very close to it though. It won't suck it in from further away.
Posted 08/11/2017 - 23:23
I have two Andbon Dry Cabinets similar to this :- http://www.ebay.co.uk/itm/New-68L-Dry-Cabinet-Storage-for-Camera-Lens-Antique/26... which I purchased on ebay some time ago, though they do seem to have gone up in price. Not cheap but then neither are lenses!
C.O.L.B.A.S victim
Posted 09/11/2017 - 01:26
I keep mine in various camera bags and desk drawers with lots of bags of silica gel (bought a job lot off Ebay last year) I havent found any problem so far.
Posted 09/11/2017 - 07:36
The open shelf with plenty of air circulation is the best option. I have seen so many older lenses ruined by being in closed bags.
Posted 09/11/2017 - 15:22
Silca gel will absorb quite a few chemicals but they are all compounds with much higher polarity than the greases used inside lenses. In addition these lubricants are designed to be involatile or they would transfer to the glass surfaces ruining your photos. So there's no chance of silica gel 'drying up' your lens grease!
Absorbents like silica gel will only absorb compounds they come into contact with (usually those in the local air). Reducing the concentration of chemicals in the air can speed up the evaporation of similar liquids, so liquid water in with silica gel will get absorbed over time...
If you have high concentrations of alcohol fumes, silica will absorb those readily enough (along with H2S, SO2 etc). Unfortunately this doesn't make it practical for passing a breath test after a night out on the tiles, or even just freshening bad breath.
At work I've used finely ground silica gel to extract traces of alcohols, ketones, ethers, phenols... from hydrocarbon samples (the sample actually passed through a column packed with the silica), ending up with far more than I'd expected!
Posted 10/11/2017 - 10:22
kh1234567890 wrote:
If you are going to use silica gel bags get the self indicating ones and regenerate them periodically when the indicator colour changes. There is a limit to how much moisture silica gel can absorb before becoming useless.
That sounds like a good idea! Where does one purchase self indicating silica gel? Amazon?
Posted 10/11/2017 - 11:29
Alternatively just weigh the dry bag and record it. Dry out when the weight increases.
Trondheim,
Norway
I know some people store their lenses in lens containers like the Lowepro lens cases series, together with silica gel. I am contemplating acquiring a few of these Lowepro lens cases for the lenses I value the most. Is there any drawback with using silica gel? Is there a possibility of the silica gel drying out the grease/oil found inside the lenses? (Maybe this is a silly question, so please excuse my ignorance...)
I am grateful for any advice on this matter!
