Lens Hoods and wat to pay
1947lcs
Link Posted 11/10/2009 - 13:10
I am still getting to grips with my K-m and proper photography and enjoying the challenge. I purchased a Tamron 70-300 and it came with a lens hood. This set me thinking if I should get a hood for the kit lenses that came with the K-m. On looking around I can pay anything from £5 to £25. Any recommendations would be appreciated
Les
Sorry about typo in the title
K5, DAL18-55,SMC 50mm f2,DA 55-300, SCM F 35-70 and all the help I can get.
gartmore
Link Posted 11/10/2009 - 13:18
Unfortunately the OEM hood is quite expensive. I know, I lost mine and found it cheaper to buy a second hand lens with hood on ebay and re-sold the lens. Made a small profit too BTW.
There are a lot of 'petal' hoods around new on ebay very cheaply and I have a couple and they work well.
George Lazarette
Link Posted 11/10/2009 - 13:38
Hoods for zoom lenses are not as effective as they might be because they have to work at the widest setting. The perfect lens would have a zoom hood (like a zoom head on a flash) and retract as the focal length gets shorter.
So given the case that most hoods are something of a compromise, I use a variety of old Takumar hoods, often with step-down rings.
Generic rubber hoods are quite good. On a wide lens you can peel them back a bit.
stu49
Link Posted 11/10/2009 - 15:49
I used a 3 position rubber hood on my 18-55. I normally leave it set in the middle position, extending it for 55mm on a bright day and retracting it for 18mm (if I remember)
Not perfect, but workable at £5 !
smc
Link Posted 11/10/2009 - 16:22
the Hoya multihoods are quite good. They should go to 28mm for the kit lens.
1947lcs
Link Posted 15/10/2009 - 18:06
Thanks for the help
Les
