K5-ii firmware update - worth it?
Mongoose
Posted 30/12/2013 - 13:23 Link
I've just checked and my shiney new K5-ii is running the original 1.00 firmware. I've always found flashing such a pricey product a bit nerve racking, so tell me fellow K5-ii owners, is it worth it?
but it does help
Gamka
Posted 30/12/2013 - 13:26 Link
Follow the instructions to the letter ensuring the battery is fully charged - no reason for it to be nerve racking. Thousand, tens of thousands or hundreds of thousands have done it already with every Pentax DSLR. The process is well documented and proven.
Mongoose
Posted 30/12/2013 - 13:41 Link
all true, but what's the benefit? even assuming the risk is 0 (and I acknowledge that with careful following of the instructions it should be pretty close to it), it's still a faff, for a start I have to go boot up my Windows PC (my laptop runs Linux).
so is there a real benefit to doing this, or just the ethereal "performance and stability improvements" which are always claimed and rarely justified?
but it does help
Mike-P
Posted 30/12/2013 - 13:46 Link
I have updated mine on every release and have not noticed any difference at all. Unless you are using AA batteries, one of the new HD lenses, the 560mm f5.6 or the newer flash units you will have to just take their word for it that there are "performance and stability improvements"
sbrads
Posted 30/12/2013 - 13:47 Link
Not being a Linux type, I may have this wrong but I would have thought you could download the Windows/Macintosh zip file and get the .bin file out of it directly in Linux and copy it to an SD card without ever needing Windows.
Mike-P
Posted 30/12/2013 - 13:50 Link
Why do you have to boot to windows, can you not download a zip file and extract it to a memory card with Linux? (never used Linux in my life so have no idea)
Mongoose
thanks guys, alas the HDs and the 560 f/5.6 are well beyond my means for now, so I think I'll leave it on 1.00 unless I encounter a problem.
but it does help
JAK
Posted 30/12/2013 - 13:51 Link
There have been six updates. Only you can decide whether it is worth updating your camera, I wouldn't like to make that decision for you via a forum! The quoted updates are:
Changes to V1.06
Corrected – Unstable performance may rarely occur in firmware version 1.05.
Improved stability for general performance
*Contents of [Version 1.05] and earlier version will be also updated.
Changes to V1.05
Correspond to the AF assist light function by white LED light for auto flash unit [AF360FGZII] and [AF540FGZII].
Optimized contrast AF when using HD PENTAX-DA Limited series lenses
Changes to V1.04
Corrected – Switch operation may not rarely work during displaying Status screen in firmware version 1.03.
Improved stability for general performance.
Changes to V1.03
Improved the accuracy of exposure when using AA batteries.
Changes to V1.02
Optimized contrast AF when using [HD PENTAX-DA 560mmF5.6ED AW] lens.
Changes to V1.01
Enabled contrast adjustment on Monitor.
(Added [contrast ]on [LCD setting ]menu)
Mongoose
Posted 30/12/2013 - 13:52 Link
I saw that the download was an exe and assumed there must be an application, if it's just a self extracting archive with a bin file in it then I could probably unzip it with an archive manager.
but it does help
Mongoose
Posted 30/12/2013 - 13:53 Link
John, thanks for that, that's all the information I needed in one place
but it does help
Smeggypants
Posted 30/12/2013 - 17:05 Link
Changes to V1.06
I wish they'd stop putting the silly "Improved stability for general performance" in every update notification. They've really made a mockery of it with V1.06
sbrads
Posted 30/12/2013 - 21:41 Link
There's 2 download options, one is an exe, the other a zip.
Conqueror
Posted 30/12/2013 - 23:10 Link
out of curiosity I unzipped the mac zip in Linux (which is what I use 99% of the time)... so yes they've just zipped the .bin by the looks of things
]$ mkdir /tmp/pentax
]$ unzip -d /tmp/pentax/ 1366296603_k5_2_104.zip
Archive: 1366296603_k5_2_104.zip
inflating: /tmp/pentax/k5_2_104/fwdc216b.bin
]$ find /tmp/pentax/ -name "*"
/tmp/pentax/
I see no reason why it wouldn't work from linux, you then just copy the .bin to the SD card. But it won't be a supported OS no doubt and if the camera got bricked they'd probably point to the OS even if it wasn't that. Might be best to follow the supported procedure.
K-3ii
Smeggypants
Posted 31/12/2013 - 04:08 Link
The OS of the computer has nothing to do with things. There's nothing to support. The .bin file is the firmware and the relevant OS reading from the card and updating itself us the Camera's OS
Conqueror
Posted 31/12/2013 - 11:03 Link
There is something to support - Depending on what filesystem is on the card itself...
I can't remember what filesystem it uses (Pentax DSLR formatted card), its probably supported well enough under linux though.
If you were using NTFS though, you might not trust it from Mac or Linux (if you were paranoid).
http://en.wikipedia.org/wiki/NTFS#Mac_OS_X
Native NTFS write support has been discovered in Mac OS X 10.6 and later, but is not activated by default, although workarounds do exist to enable the functionality. However, user reports indicate the functionality is unstable and tends to cause kernel panics, probably the reason why write support has not been enabled or advertised.
http://en.wikipedia.org/wiki/NTFS#Linux
Due to the complexity of internal NTFS structures, both the built-in 2.6.14 kernel driver and the FUSE drivers disallow changes to the volume that are considered unsafe, to avoid corruption.
K-3ii
