K3 grip - battery not recognised
Posted 10/06/2018 - 16:42
There is a small pin inside the grip just under the right hand spring that registers that a battery is in the tray. does that look to be ok?
Are all the pins that connect to the body moving freely?
Barrie - Too Old To Die Young
Posted 10/06/2018 - 18:24
both sets of connections look fine Barrie... thanks
AKA Welshwizard/PWynneJ
Richmond/Denbigh
LCD said batteries were flat - go into menu system and display tells me there is no battery in the tray. THinking the battery might be flat I placed a freshly charged battery in the grip - ZERO, nothing. Same battey in the camera - FULL CHARGE. Yet if I take a photo in portrait mode with charged battery in camera, the wheels and shutter button work...
Batteris are all OEM D-Li90.
Grip on the blink? anything else I should look for?
Ta
