K3 & F*250-600mm, little birdies!
#3 is a great composition.
#1 is more of a personality shot, but I'd desaturate the background slightly to help the birdie pop a bit.
photos. 2 and 3 are my favourites.
The 1st one looks focussed just in front of the bird, judging
by the grass.
Had an invasion of yelllowhammers last week after seeing none at all at the same spot the weekend before. Such bonny little birds, but I didn't manage anything decent off the ground, which you need to throw the background out.
Outstanding work.
Thanks!
Danny, the second and third images really hit the mark for me personally, they work really well. The images also seem to have more pop to them than the Blackbird image you uploaded the other day, have you processed these images any differently?
Hi Fletcher, processing is almost identical to the Blackbird, bit of noise reduction on the RAW file and edge sharpening on the bird and brighten the eye up a bit. The 'pop' is more down to the clean background, certainly helps a lot.
Will definately be sneakily setting up some more photogenic branches with clean backgrounds around the bird feeders if I can get away with it!
As "archive the species" shots #2 and #4 are perfect
It was a shame no other birds sat on that fence post, it was perfect when the sun was out!
Did try darkening the background on the 1st shot and didn't quite work for me, didn't think of desaturating, so will try that when I get home!
These are great. That lens has really nice bokeh for bird
by the grass.
The focussing on the Yellowhammer was a combination of leaning out of the bird hide whilst trying not to scare it off, trying to get a shot at all as the little bugger just would not sit still, narrow depth of field and learning the new focussing modes on the camera, it wasn't easy!
Having said that I do think it might be front focussing a bit / would like it to back focus a bit more as when shooting small birds, it's a lot easier to focus on the body than the eye. The problem here is at say 15ft away and at 600mm the depth of field is so narrow that even at F10 on a tiny bird, the 'shoulder' can be in focus with the eye out of focus!
Lovely seperation from the background in #2 and #3 Danny.
Thanks, that fence post came in handy and the branch was conveniently cable tied between the 2 bird feeders!
Had the same problem with the Yellowhammers, they were spooked quite easily and were almost always on the ground but they are my first shots of them so will do for now!
Aylesbury,
Bucks.
Website・Blog・Gear・Twitter・Facebook
