K200 v K20 viewfinder Accuracy ?
Posted 14/08/2009 - 00:47
Sounds like user error to me. Or a damaged camera.
Posted 14/08/2009 - 05:08
K20d has an excellent viewfinder and I haven't got such faults ever. I wonder if you use spectacles, because it may cause some problem viewing through the viewfinder.
Posted 14/08/2009 - 08:17
My K200 'finder isn't as bright as a K20, but as long as the subject is centred it works fine.
The last time I cut a head of was with my AGFA range finder, that was user error!
Cheers, HG
PPG entries.
PPG entries.
Posted 14/08/2009 - 08:53
so when a review says the k20 has a 95% viewfinder accuracy ,(what is the k200 accuracy ?) does that mean that 5% is removed equally from top/bottom , sides ? going to try some test shots to determine if theres a fault . thanks, tim.
Posted 14/08/2009 - 10:13
Yes, it means you're seeing the central 95% of what the sensor captures. The K200D shows slightly more at 96%.
Joining the Q
Posted 14/08/2009 - 11:05
Accuracy is completely the wrong word. It's 100% accurate in terms of centering, but it crops 5% of the picture.
Posted 14/08/2009 - 11:30
There are reasons for this. Basically allowing a small amount of crop in the viewfinder gives a bit of leeway to avoid bits being chopped off images, but the real reason is more probably that a slightly smaller pentaprism/pentamirror becomes possible and that reduces the size of the camera slightly, reduces the weight and may reduce costs as well.
Posted 14/08/2009 - 22:16
I thought that a 100% viewfinder are harder to align probable since there is less room for error then with a 95% viewfinder and that was the reason why they use a 95% viewfinder.
Posted 14/08/2009 - 22:19
I've heard that before but I'm not sure if it's true or just one of those urban myths. Be interesting to know
Joining the Q
Posted 14/08/2009 - 22:43
I expect both explanations are correct.
Posted 16/08/2009 - 10:00
tried a few test shots of a picture frame on the wall ,everything looks fine ! must be my technique at fault . need to try harder. thanks for the info.
tim.
tim.
Blackburn Lancashire
