K10D OMINOUS FEEL AND SOUND OF HEAVY OBJECT MOVEMENT INSIDE BODY
Posted 03/08/2016 - 14:21
If the heavy object is only noticed when you switch the camera on, it could just be the sensor cleaning operating.
have a look at this link it should give you the shutter count
Barrie - Too Old To Die Young
Posted 03/08/2016 - 14:27
100 is the folder name. It implies 7269 shutter releases. When it reaches 9999 the next step will be folder 101, which will start from 0001. Then folder 102, and so on. Nothing to worry about.
A thunking noise is probably the sensor assembly moving, until such time as the camera is switched on and the SR system takes command of it. Again, nothing to worry about.
Posted 03/08/2016 - 14:41
Thank you both
Unfortunately the thunk occurs when switched off and when switched on and with SR on and off. I noticed it the first time I tilted the camera from landscape to portrait while taking pictures. Testing it again now it is doing it when tilted on its axis in the same plane in use. In other words not laying it on its back or front.
Just did sensor cleaning and could hear something going on and the clunking did not happen on moving camera. however, now cleaning finished and camera back on, the clunking is still there.
I suppose if all else is working I should ignore it. Probably nervous about just spending £100 on my first digital.
Thanks again
Thanks again
IMA CARDIE
Posted 03/08/2016 - 15:01
If it's all working it's no doubt the SR system - the sensor array moves. So just enjoy it, you've spent £100, but that's a bargain compared to the pleasure you should untilmately get from using the camera.
Posted 03/08/2016 - 15:03
Thank you bforbes for the link.https://www.camerashuttercount.com/
I uploaded an unedited pef and it returned a result of 37,064 on Pentax K10D so it got the camera right.
D'you reckon the counts right ?
IMA CARDIE
Posted 03/08/2016 - 15:13 - Helpful Comment
If you upload the last image the camera took, that site will take the shutter count from it.
SRS, who are very well respected on here, have a K10d @ £129 with a years guarantee. link So I would have to think hard about getting one repaired.
Posted 04/08/2016 - 08:55
My K10 has always made a thump when shook. It also makes a similar noise when the startup clean is set.
I bought it new and it got a lot of use until I bought the k5. Don't worry, mine has had a lot of rough handling on days in the mountains but has never missed a beat.😁
Bob
Posted 04/08/2016 - 18:01
My K10 has taken 32,000 pictures. I believe Pentax cameras of this generation should last for c.100,000 shots.
Best wishes,
Robert Adams
Ernst Hass
My website: http://www.ephotozine.com/user/bwlchmawr-199050 http://s927.photobucket.com/home/ADC3440/index
Robert Adams
Ernst Hass
Posted 05/08/2016 - 07:26
My (ex) K10D did the same when tilted, it's normal and is part of the SR system, nothing to worry about.
It actually mentions it in the handbook
Regards,
Michael
Michael
Posted 18/09/2017 - 14:22
reply to an old post i know, but Hey ! i'm new to the site and have a lot of catching up to do.
My K10D has 7005 actuation's as of 18-09-2017 and mine does the same. No Worries.
8 years
As you can see from the title I have a worry. It doesn't move far - just enough to be obvious that there is play in something and it feels like something quite substantial. Apart from flash always whiting everything out and a few unaccountable reciprocity probs the camera appears otherwise ok.
Has any one any comments please ?
In regard to actuations, I got nothing from Photome but in top right hand corner of info is 100-7269 does this imply 726,690 shutter releases ?
