K100D Super battery failure
Posted 08/12/2010 - 21:54
Sorry to hear your problem - are the contacts clean?
Posted 08/12/2010 - 22:32
"Like most I have battery life issues with both the K100D and Super models"
Most people have never had battery issues. Like many I use Eneloops and couldn't be happier. Before that I used several other brands and they were OK too.
"the camera body is effectively dead"
I am sorry to hear about that! Mine worked fine until I dropped it off a waterfall... and even after that it was OK, though the viewfinder was mucky. I have never heard of the battery compartment failing but anything that can happen will... eventually. If it is under warranty get it seen to.
"I had a fatal failure on the K100 that required a warranty replacement of the main board. Currently I have had no issues with either the K10 and K20 bodies. But I am lossing faith in Pentax. "
I would lose faith with a company that didn't honour warranties. But not the other way around. Every brand has failures and Pentax is no different. If anything, Pentax cameras are built to take a lot more abuse than other brands at the same price point.
Posted 08/12/2010 - 22:36
Sorry to hear that you're having problems with batteries, but why would that make you lose faith in Pentax? I have a K100DS which I still use occasionally. Never had any problems with it. Are you sure it's got nothing to do with -0 temperatures?
Dodging and burning are steps to take care of mistakes God made in establishing tonal relationships. - Ansel Adams -
Posted 09/12/2010 - 22:19
I have a K100DS that has a battery life of a few hours but I put this down to it being totally immersed in water on a ride in Orlando - 'Jaws' - despite being in a camera bag beneath my legs!
It also doesn't switch off once switched on - I have to open the battery compartment.
Luckily I was able to claim under my insurance.
Posted 15/12/2010 - 22:28
Try Energiser Ultimate Lithium, about £7 for 4. Not rechargeable, worked with my DL2 when I had same problem. None rechargeable are 1.5V, but rechargeable 1.25V. DL2is backup body to my GX10 so I take batteries out when not in use,often when putting back, first insert shows low battery, but a re-fit gives full battery. I have taken plenty of shots on one set of these over last 2 years on what, like you, I thought was a broken camera
ist*DL2, 18-55Mk1, DFA 100 f2.8 Macro, Samsung GX-10, 10-17,18-55,50-200, Sigma 10-20,100-300, 150-500 Tamron 18-200, Jessops 360AFDP
ME Super, MX, 2No. 50mm f1.7, MZ-10, 28-70 f4, 28mm f2.8, Samyang 500 & 800 f8 mirrors, Vivitar 2x TC, K-01, K-30
Posted 15/12/2010 - 23:36
I also use the K100DS but only lightly. I've never had issues with lithium batteries and generally try and find cheap CRV3s (eg from EBay) as they seem to last for a very long time. Sorry to hear about your problems and hope you find a solution.
Posted 17/12/2010 - 01:59
I had the same problem. It may be the battery "door". Mine was very loose on my 100D
Posted 29/12/2010 - 17:08
Thanks to everyone for your help. The K100's seem to be very prone to battery issues. At least the K10D and K20D with the with the rechargeable Li-on batteries have never caused any issue.
Posted 29/12/2010 - 18:19
The power supply may have blown a fuse. The internal clock battery would provide enough power to display the depleted battery warning.
If this is the case then it should be a quick and straightforward repair (ie. cheap), but probably one that only Pentax would undertake. Why not give them a call and see what they say?
I had this problem with my GR-D and Ricoh replaced the fuse free of charge, despite it being a year out of warranty. Obviously Pentax aren't obliged to carry out work for gratis (and it might be a more complex job - I have no idea where it would be located on a K100D) but if you ask nicely you have nothing to lose - the camera won't work as it is...
Joining the Q
Posted 29/12/2010 - 18:26
I have had my K100 D for a few years now and never had a problem with any batteries.
Ian
Ian
Posted 25/06/2015 - 20:52
Sorry to resurrect an old thread, but my K100DS has just developed this problem. I even tried an external power supply, and still all I get is the "low battery" symbol.
I guess this camera is long in the tooth now, so is it worth getting it repaired, or is this a sign that it's time to move on. Or do I go back to my ME Super and film?
Posted 25/06/2015 - 21:11
Sorry to hear of your woes. I dread anything going wrong with my K100D as I still use it regularly. As you say, these cameras are getting old now... You might be able to find a replacement on evil-bay, one which has been lightly used.
For goodness sake don't start using film again. That would be a bad thing. I get the occasional dud CD but I don't dust off the 78s!
Best wishes,
Robert Adams
Ernst Hass
Robert Adams
Ernst Hass
