K1 and beep
Posted 15/12/2016 - 15:53
Focus hit? If not when does it beep :
Otherwise could it be when you're walking backwards to frame a shot to warn others nearby of your presence?
Posted 15/12/2016 - 15:55
When do you get the beep? While performing what action?
Posted 15/12/2016 - 18:46
A few seconds after I switch on the beep sounds once then after another few seconds the beep occurs for 6-10 secs then stops.
JAK - tee hee!
JAK - tee hee!
Posted 15/12/2016 - 19:13
I think I may have solved it, or a least cured it. I had a single flu card in the camera. I replaced it with a pair of SD cards and it doesn't beep. Strangely though it doesn't bleep now when I put the I put the flu card back in. maybe it was the flu card trying to make a connection.
Posted 15/12/2016 - 19:46
Ah, there you go. It does that when you stick it in a PC as well. Glad it's sorted
Posted 15/12/2016 - 20:30
Sherlock homes eat your heart out
Posted 15/12/2016 - 20:31
Holmes !!
Posted 15/12/2016 - 22:37
Sitting in a hide with some upthemselves Canon users I realised I was the only one bleeping when in focus. Found out how to turn it off later.
Lancashire
