K1 and Aperture Priority instead of Manual.
Be well, stay safe.
You write about EV as follows "don't know why but read it somewhere as best to do for the K1"
It has always held good for any camera to underexpose... film or digital.... I use -o.3 or -o.7 as a standard.
The reason is that you can always pull detail out in the darkroom.... or nowadays with Lightroom or Photoshop etc.... but if you overexpose an area of white and blow the detail, that is it.... gone forever!
Never be afraid to talk about your techniques...
"Give a thousand photographers...
the same camera, lens and scene...
and you'll always get a thousand different takes!!"
Anon.
The reason is that you can always pull detail out in the darkroom.... or nowadays with Lightroom or Photoshop etc.... but if you overexpose an area of white and blow the detail, that is it.... gone forever![/quote]
Ah yes that's it, I remember now thank you, must have been a .Senior moment,
Thanks for the comments
Av mode is the one I use most of the time when hand holding a camera. Especially for scenes like this where DOF is your main priority and the light is bright enough to not worry about too slow a shutter speed.
I tend not to dial in a general underexposure compensation, but then I do rely on reviewing the histogram for each shot and adjust accordingly. Where there is a high contrast scene I also recommend bracketing your exposures and merging them in software, or simply use the HDR feature in the K1 directly.
I almost always use Av mode on any camera I use. I find it easy to get good results while retaining easy control of depth of field and overall sharpness.
Pentax hybrid user - Digital K3 & K200D, film 645 and 35mm SLR and Pentax (&other) lenses adapted to Fuji X digital
loadoftripe
Member
loadoftripe
1.
2.
3. Brittany Ferry the Pont Aven returning to Plymouth on the Horizon.
4.
5.
6.
7.
8.
