K1 & FA 50mm f1.4 lens fine focus calibration issue
johnducguz
Link Posted 25/04/2021 - 13:26
So I've adjusted the FF on the K1 for my lenses but the 50mm gives me issues.
I've a sheet of paper angled at 45 degrees away from me with horizontal lines on it. 2 sec self timer set, set to f1.4, focus on the middle line & take a shot. Zoom in on shot image & it shows front focus. Don't alter anything but place hand in front of the lens to force focus to change, remove hand, focus on the middle line again & take a shot. Zoom in & now the line's in focus. Repeat & this time there's front focus again. Repeat & middle line's in focus.
So the camera isn't finding the same focus point each time meaning any fine focus adjustment isn't final.
I've made adjustments 3 times previously & still been left wondering why some shots aren't sharp. If the combo finds a different focus plane each time any adjustment isn't likely to work.
Anyone any idea what's going on? Why's this particular camera/lens combination giving differing focus results.
I'm baffled as my other lenses once adjusted have remained ok.
pschlute
Link Posted 25/04/2021 - 14:59
That happens with PDAF, although a 50% miss ratio is very poor. 10% is quite normal
I would give the AF sensor a blow with a rocket blower in case you have dust on it, but its a long shot.
Do you notice how the accuracy compares when you get the lens to focus from infinity versus from closest focus distance ?
johnducguz
Link Posted 25/04/2021 - 15:45
Must admit I hadn't tried it at the extremes, I'll give it a go.
A quick blow around with the rocket can't hurt either.
Thanks for the input
pschlute
Link Posted 25/04/2021 - 16:11
Mirror up and the AF sensor is in the bottom of the mirror box
Do 10 tests from each extreme to get an accurate assessment.
FrankV
Link Posted 02/06/2021 - 15:35
I just recently bought a K1, to say it’s a disappointment is an understatementi.
It doesn’t focus properly.
Chrism8
Link Posted 02/06/2021 - 15:45
The K1 is a superb camera, there's obviously something wrong somewhere, care to elaborate on " it doesn't focus properly " what lens are your using, settings etc ?
Chris
Samyang 14mm F2.8, Pentax DFA* 70-200 F2.8
pschlute
Link Posted 02/06/2021 - 15:54
The k1 focusses perfectly, you are doing something wrong.
Mike-P
Link Posted 02/06/2021 - 17:25
Wow, that's a bold statement, although unlikely it may just be a duff camera.
. My Flickr
pschlute
Link Posted 02/06/2021 - 18:02
Indeed it may be. But without any information from the poster about what his settings are, and some images to diagnose, I have no idea.
The K-1 has been in production for 5 years now. If it had a general focussing issue I think it would be apparent by now.
The most common mistake is someone moves from an older camera to a 36MP sensor unit like the K1. They then look at the images at 100% and see that focus is off without realising it was just as inaccurate on their older camera.
There is a reason all manufacturers have AF adjustment menu items.
Mike-P
Link Posted 02/06/2021 - 18:59
Exactly, so before declaring him incompetent perhaps it would be better to find out those settings because if you look back at his previous post he has been a long time user who is probably fairly well clued up on how to use a Pentax body
. My Flickr
pschlute
Link Posted 02/06/2021 - 19:11
I am so used to folk moaning on forums of all types these days that I give these kind of posts short shrift.
If he wants help i have lots of experience fine tuning lenses with the K-1, and have offered that help on many occasions.
If he wants to just gripe I have no time.
