K-x and the HD Pentax-DA AF Rear Converter 1.4x AW
grambuch
Posted 25/05/2016 - 13:53 Link
According to the spec on the website, the rear converter does not include the K-x as one of its compatible camera bodies, and phoning Ricoh support shed no further light on this topic. Do any members have experience of this combination, say with a DA*300mm or a DA 55-300 zoom?
Thank you much if you can help.
Posted 25/05/2016 - 14:40 - Helpful Comment Link
It's a matter of supporting the AF function. The converter will presumably be MF only on the K-x.
Blythman
Posted 25/05/2016 - 22:09 - Helpful Comment Link
It works fine and AF works, with the limitation that the extended focal length is not recognised. This also means the shake reduction applied will not take the 1.4x into consideration.
Alan
