K-30 under exposure
Nick13452
Posted 17/06/2016 - 12:07 Link
I am having a problem with my K-30. When using it for still photography I am getting vastly underexposed pictures (almost black), but in video mode I get normal exposure. I have checked the settings, and have also reset the camera to factory settings. Nothing seems to correct this problem. Has anyone got any ideas?
Posted 05/07/2016 - 03:51 Link
It could be aperture block failure, if so it needs to go in for repair. Do a search on Google, you can find out a lot more about the symptoms.
richandfleur
Posted 05/07/2016 - 09:45 Link
Yep, as mentioned above, it's a very well known problem with the K-30 and K-50 models.
The fix is to send to a repair centre, which is covered if you are under warranty. If not, Pentax don't want to know you unfortunately, despite it happening to many owners. I hope you are within your warranty period :
Nick13452
Posted 05/07/2016 - 10:36 Link
Thanks for your help. Sadly I have discovered this by some research on the web. Not under warranty now (bought in 2013). Pentax used to be very reliable.
richandfleur
Posted 05/07/2016 - 11:51 Link
Hardware wise they still mostly are, except for this specific faulty component. It really should have been a recall, and probably would have been if they had all failed at once together.
The only other reliability issues I know of are more software based, such as the k-3 mystery mirror flap situation, or my k-30 intervalometer that just stops randomly. I know others have experienced lockups that require the battery to be pulled out, but don't know the specifics around this.
I don't think Pentax are less reliable than any other brands, but it's the putting right that counts, if something does go wrong, that interests me more...
Nick13452
Posted 05/07/2016 - 14:55 Link
Don't get me wrong, I've been a happy Pentax user since around 1974 when I had my first one (a Spotmatic F). I've had several others, film and digital, that's why I feel very disappointed with the K-30. I need to decide whether it's worth spending the money to have it repaired.
PS. My brother lives in Kerikeri, having just moved from Auckland.
