K-3 focus points
Posted 22/12/2020 - 19:29
Have you checked the viewfinder diopter adjustment dial hasn’t been moved?
Posted 22/12/2020 - 19:32
Have you tried AF mode, Select, OK. That should centre the Focus point
Barrie - Too Old To Die Young
Posted 23/12/2020 - 07:31
Hi both. The diopter adjustment is on maximum where it always is so I can use the camera without my glasses. All the various focus point selections work fine. I usually have it set to a single focus point and select the one nearest to the point I wish to focus on. The centre one is still inside the centre circle, but offset slightly to the right.
Many thanks, Kris.
Many thanks, Kris.
Posted 23/12/2020 - 08:54
Has the camera had a knock recently? Are the other focus points absolutely symmetrical or offset in the same direction as the centre point? It sounds like something is out of alignment. My K3 centre focus point is dead centre and always has been.
Posted 23/12/2020 - 11:03
Why does everybody say "impact" when they mean AFFECT?
Pentax K1-ii and MZ6
ONE UNITED Member
ONE UNITED Member
Posted 23/12/2020 - 11:11
The lines are I think marked on a detachable focus screen mounted above the mirror, check if that has moved slightly but be VERY careful as it is too easy to mark with scratches and fingerprints.
Posted 23/12/2020 - 13:54
If you impact something you have an impact on how it behaves, or indeed you also affect it. English is a very rich langauge with many ways of expressing the same ideas.
Posted 23/12/2020 - 16:59
Hi.
I have had the same "fault", but it was a user fault, I had, chosen a a focuspoint that was not in the center.
I dont remember exatly how I did it. When you have all the focuspoints you can chose a point outside the center and then it will focus there.
Check where your focuspoint is.
Hope this can help you.
K-3III/K-1 II + film cameraes
I love my Pentax, all of them.
Posted 24/12/2020 - 08:57
Sounds like the focusing screen has been knocked a little out of where it should be. I'd have a look, gently open the little brace that holds it in place and close it again to see if that helps.
Posted 24/12/2020 - 17:42
They are all offset to the right. The point that is immediately to the left of the centre point is overlying the left-hand curved line. Has the camera had a knock recently? Are the other focus points absolutely symmetrical or offset in the same direction as the centre point? It sounds like something is out of alignment. My K3 centre focus point is dead centre and always has been.
Thanks, Kris.
Posted 24/12/2020 - 17:43
erikro wrote:
Hi.
In this case this isn't the problem. I can select focus points fine, but they are slightly off where they should be. Thanks, Kris.
Hi.
Posted 24/12/2020 - 17:44
I've have a look. I wonder if the old tool for opening the focus-screen tray will work with a K-3...
Posted 25/12/2020 - 09:17
womble wrote:
I have one somewhere from my Katzeye screen for the K200D but if I remember correctly a pair of tweezers will work too.
I've have a look. I wonder if the old tool for opening the focus-screen tray will work with a K-3...Sounds like the focusing screen has been knocked a little out of where it should be. I'd have a look, gently open the little brace that holds it in place and close it again to see if that helps.
Hertfordshire,
mostly.
Has anyone else had this problem? It doesn't seem to impact the focusing of my AF lenses, but I have noticed lately that I am getting much sharper images with MF lenses if I use live view rather than the focus screen / focus confirmation.
Thanks, Kris.
