*ist D - HELP!
Anonymous
Link Posted 19/02/2004 - 22:02
I just got a brand new *ist D delivered today, and I can't get the shutter to realease. I can turn it on, go through the menu, but AV - - - keeps flashing on the display and I can't get it to take any pictures! I looked in the manual under troubleshooting, but I didn't see anything for the problem that I'm having. I've taken out the batteries, microdive, and removed the lens and then put them back, but no luck. Any ideas?
Malcolm Riches
Link Posted 20/02/2004 - 06:39
I had this fault with mine and it turned out to be a problem with the contacts on the camera body and any lens I used. I returned it to Camerworld and it was replaced by return.
The camera behaves as if no lens is attached.
I suggest speaking to the supplier and asking for a replacement.
Anonymous
Link Posted 07/03/2004 - 02:38
I know this is late, but the issue sounds to me like the aperture ring is not on A. and if this is a manual lens then you have to set the mode to hyper-program mode and set it to work with "other than A" on aperture.
ShotGun
Link Posted 10/03/2004 - 02:47
Hi All,
Been away for a while....
yes i think the previous post by "Guest" is right. If you are using a lense with an appreture ring, you must set it to the "A" position. Buy defaut the *ist-D is set to operate with this setting.
Rgds.
http://www.photonski.com/shotgun http://www.pbase.com/santyluib/first_istd_sample_photos
"It's only a Pentax!"
