Issue with ND filters on Pentax 12-24mm with Pentax K3
Roger
No problem with the lenshood, but I noticed that it is shaped quite tight, at 12 mm if the lenshood is not properly set in place ( i.e slighty rotated ) it intrudes immediately.
But still what concerns me the most is the strange "Moiré" in the bottom..
Tim
Some of my vaguely better stuff
Using two filters will also, as already mentioned, certainly result in vignetting.
Pentax K-1, K-3,K-5,
Alan
First of all thanks for all your answers.
-Indeed I am using 77mm round filters, and when stack together they block the field of view, so I am good to buy a 16 stops ND filter (more difficult to find, any recommendation ?) That's explain the "vignetting".
- Meanwhile regarding the aberration or interference I retain the explanation given by Northgrain... I will do some tests with some tape..I keep you posted!
The light interference in the bottom part of the frame might be the problem I sometimes get - forgetting to block the viewfinder with the wee cover or some black tape, so light bleeds in through there. I've had some good images ruined from this
That's why I always wear a hat Tim
Alan
What can I say. I just get overexcited sometimes and forget the proper workflow
Tim
y_vigourel
Member
I recently bought a used Pentax 12-24mm f4 lens to start into wideangle photography, so far very good results with this lens mounted on my K3.
As I wanted to start taking long exposure shots during daylight, I bought two ( expensive...) brand new 77mm ND filters, one ND8 and one ND1000 from the Hoya PRO ND series.
In order to reach 30 seconds of exposure during daylight without need to stop down up to f22, I mounted ND8 and ND1000 together on the lens, but then the results are quite surprising at 12mm as you can see in the attached image:
-There is a physical vignetting from the second ND filter ( which remove all the interest from the wideangle lens...)
-Worse there is a kind of chromatic aberration or more likely interference/Moiré that occurs on the lower end of the picture !
Important to note that both ND Filters works fine when used separately.
Do you have any solution or explanation ?
I did a quick seach, but I did not found such issue reported before...so any help will be very appreciated!
Cheers from Toulouse, France
