Infinity (and beyond)
Posted 10/09/2010 - 09:12
I don't understand, infinity is infinity how do you go infinity+1?
Barrie - Too Old To Die Young
Posted 10/09/2010 - 09:38
Do old MF lenses stop at infinity? The only MF lenses I regularly use at infinity are both long mirror lenses, and both focus considerably past infinity (annoyingly so). I guess that may be a special case because they are mirror lenses though.
Tim
Just nipped outside and did these very unscientific demonstrations with the DA* 50-135 @50mm, looking at a house about 50m away - a DoF calculator has the near point at 23.5m which is about the end of my garden.
- Only cropped for 1:1, no sharpening or any PP
Infinity :
Beyond Infinity :
Infinity :
Beyond Infinity :
Posted 10/09/2010 - 10:05 - Helpful Comment
Most lenses now use plastic material in their construction, and they go "beyond" infinity to allow for plastic components thermal expansion. Even long lenses made of metal will suffer thermal expansion, too.
Posted 10/09/2010 - 10:11
Won't it be because of the AF adjustment on the camera. They probably set infinity on a camera that was on the limit for being out of adjustment.
Some Vivitar lenses such as the Series 1 28-105mm let you adjust infinity by rotating the front element.
Posted 10/09/2010 - 10:27
Tim wrote
I think that answers bforbes
"Two lines that meet at infinity"
But how far away is that?
Geoff
And so does my mirror lens. But I suspect that what Tim and I (and others) mean is that one can turn the focus ring so that the infinity mark has gone beyond the index mark. The only MF lenses I regularly use at infinity are both long mirror lenses, and both focus considerably past infinity (annoyingly so). I guess that may be a special case because they are mirror lenses though.
It's a bit like the definition of parallel lines:I don't understand, infinity is infinity how do you go infinity+1?
Geoff
X-5
istDS
K2000
P50.
X-5
istDS
K2000
P50.
Posted 10/09/2010 - 11:05
I've never been entirely sure how far away infinity should be anyway - I recently spent some time trying to get an old K 28-50mm adjusted by the simple approach of attaching it to my Super A (which has a split focus screen), putting it on a tripod, then lining up on a ridge line which I would guess to be about five or six miles distant. Hopefully that was far enough!
Posted 10/09/2010 - 11:52
Should be. The moon would probably be better I've never been entirely sure how far away infinity should be anyway - I recently spent some time trying to get an old K 28-50mm adjusted by the simple approach of attaching it to my Super A (which has a split focus screen), putting it on a tripod, then lining up on a ridge line which I would guess to be about five or six miles distant. Hopefully that was far enough!
There is a method where another camera with a lens known to focus on infinity accurately can be used as a collimator to set up a 2nd camera and lens to infinity. See here
Posted 10/09/2010 - 14:07
It is all about the focus point changing as the lens expands and contracts. This becomes relevant with big telephoto lenses in particular.
Posted 10/09/2010 - 14:58
Who could resist a little buzz?
Tim
Twickenham
