I need advice, again!
Posted 07/08/2011 - 16:48 - Helpful Comment
Not something simple though...
http://www.akelstudio.com/blog/category/jewelry-photography/
Posted 07/08/2011 - 16:50 - Helpful Comment
I'm no expert either, but what about trying the photo against a dark background and have the diamond at some angle rather than straight on.
Barrie - Too Old To Die Young
Posted 07/08/2011 - 17:00 - Helpful Comment
Try halogen light to bring out the sparkle, and maybe place the ring in it's box, if you still have it so you can photograph it from above.
Posted 07/08/2011 - 18:48 - Helpful Comment
A few things worth trying that may help. I personally would put the camera in manual mode and stick it on a tripod, if you have a shutter release use it, and use the Mirror lock up function
Try taking a three to four images and place your focus point (red dot) on different areas of the ring then focus stack them using photoshop. (don't move the camera)
Try taking a few images at f/8 f/9 f/11 to see which provides better focus. DOF gets shallow very quickly with macro work.
Try sandwich lighting the ring and use a softbox from above, i personally would pick a darker background. If you use a black background use -2 EV or -1.5.
If you are limited light wise use window light, or make some reflectors with tinfoil.
The key to getting this ring to shine is light, you just have to learn by trial and error and be creative.
Stephen interesting link thanks!
Gareth
Gareth
Fletcher8.
Pennsylvania,
USA
However, I have found that photographing a Diamond Ring is not quite as easy as I thought it would be. I tried to capture the brilliance of the Diamond in the light box that I have. I used my Tamron 70-300mm Lens with Macro, which is the only Lens that I have with any Macro compatibility.
I set the AV to a higher number to get the whole ring in focus. The Image did come out better, thanks to some of the help you all gave me before. The problem is that I just can't seem to get the whole Diamond in a real, sharp focus. Some of it is a bit "blurry." I even wanted to try and capture the sharp cutting of the center Diamond. I did not use my Flash, as was explained earlier. The stand for the ring was about all that I could find, since I am by no means a Pro at this kind of stuff.
I know that I can do a better job, but just don't know all the "tricks of the Trade." If you, out there have any advice or better knowledge please do not hesitate to let me know what you think. You have done it before, so do it again. I do read what is explained to me.
[IMG]http://i404.photobucket.com/albums/pp127/Corker2/Different%20Images%20Taken%20By%20Me/IMGP2552.jpg[/IMG]
http://s404.Photobucket.com/home/Corker2/index
I'm just full of questions . . . It's the only way I learn anything! I have so, so, much to learn using my Pentax K100D DSLR
