How to I roast Photo's to a CD please?
Always be kind to people
link
https://www.facebook.com/pages/Photographs-by-an-angel/262352847143059
link
Select the sub-folder or individual photos you want to burn to disc
Towards the top of the folder window you'll see a tool-bar with the word 'BURN' towards the right-hand side
Click on 'BURN' and follow the instructions
link
link
No problem. Come back if there's an issue.
I didn't want to start a new thread about this problem. I tried following the instructions on how to burn a CD in windows 7, but a notice kept coming up asking to put in the right CD I put in a TDK and a Verbatim disk, but it wouldn't accept either which is a pain. Both the disks are new and clear of anything, so I don't know why this is happening.
Someone mentioned a programme called AShampoo, anyone use that please? if so, what's it like and is it worth having?
I don't mind Google Picassa, but accoring to my picture folder on my hard drive, there's more image's on that then I have on the Picassa.
Thanks very much.
link
link
I use a small program called CDburnerXP to write my discs.
yours may not so you could check that.
How do I do that please? I ususually keep between 100-200 image's on a CD, is that too many?
Whats CDburnerXP and is it good? I'm running windows 7 so it might not work.
I also notice I have a message at the bottom of this screen which is saying
"Please calibrate your monitor so you can see 16 different shades from pure white to black."
What does this mean please? Sorry to ask questions, thanks.
link
link
Are you trying to burn too many photos to a CD?
They (CD's) have a maximum capacity of around 700mb of data. That could easily be only around 60-70 High Res JPEGs, certainly on my K5II.
The CD burner software in Windows 7 is fine for what you're wanting to do by the way. Look first to whether you're trying to put too many photos on to a CD.
You say also that you usually get 100-200 images on a CD. How have you done that if you're now saying you can't? Was it a different computer?
Lastly, don't worry about the 'Please calibrate..' message. That's here on the Forum pages and is only to help you get the brightness sorted on your monitor. It doesn't affect your ability to burn to CD. Come back to that in another thread!
Have you burnt CD's before on your machine? Music maybe? Did it all go ok?
Only when doing a DVD for someone, I havent done it this way since my tower was upgraded.
CD's have a maximum capacity of around 700mb of data. That could easily be only around 60-70 High Res JPEGs
So I can only burn 60-70 images per disk?
link
link
If you're talking about 11mb images, yes that's correct, but it depends on what size images you take on your camera as to how many will actually fit. Do you know your average JPEG file size?
Also, you mention DVD. They'll take many more images than a CD would. Why not use DVDs? The same software will burn to CD as well as DVD, assuming you have a DVD burner in your PC, which I presume you do from you saying 'Only when doing a DVD for someone...'
Have you got, or have you considered an external hard drive, one that plugs into a USB port on your computer?
I've used AShampoo regularly.
Much better than the windows burner, and as it was free well worth the money!
http://www.imgburn.com/
Just choose "Write files or folders to CD/DVD"
The site that hosts the Imgburn download also has
some good guides and other Freeware for movies, stills etc.
http://www.digital-digest.com/index.php
I got an external hard drive from Maplins.
What do I click on to do a picture CD please?
link
link
AuraTodd
Member
Salisbury
It would make it easier I hope then going through Picassa.
Thanks.
link
link
