How many shots has my IST D Taken?
I wonder how many will reach that, not because they can't but because they will be upgraded long before.
So far, my *istDS is up to just short of a modest 4000 shots....
Both look new apart from a tiny bit of paint loss on the hot shoe. And, more importantly, they work properly - for the moment.
Probably the most wear for mine is on the K-mount - changing lenses in a hurry
In fact, AFAIK, all Pentax cameras have the ability to reset the image count back to zero after a card change In other words, you can't get a genuine, reliable, indicator of age and amount of use - perhaps only by examining the wear and tear.
I say 'about' 15,000 because inexplicably, the numbers jumped backwards by a few hundred a while back, not long after I went past the 10,000. I'd got to about 10,900, when the next images were numbered 10,200 odd. THAT was a pain in the backside as far as image numbering and saving on the computer was concerned - "Do you want to overwrite the other file?" - NO I DO NOT!!
Dan
P.S. George, do you wear silk gloves when using your D's? Actually, and seriously for a change, are you more studio based? Or do you just treat your cameras exceptionally well?
I presume they all do that - did the question assume that the life of the camera would exceed 9,999 images?
yep i'm afraid so!
I've had the camera since early this year (bought from my dad, he owned it from new) But i've gone round the clock several times since I've had it. Can't tell exactly how many but on a busy weekend i can shoot a couple of thousand shots. (don't think i'm quite up to George's level though...!)
Rarely gets used indoors - I mainly shoot motorsports and car meets. The camera gets used in all weathers - i will confess it's been rained on more than a few times (i've got a cover for it - but if it starts to rain while i'm shooting then i'd rather get the shots then stop when i get the chance)
To my eyes the camera looks pretty much new - no appreciable wear anywhere.
George - I'm guessing you may have yours serviced periodically to keep them in good shape - any recommendations?
I asked for it to be serviced at the same time, and it came back with in lovely shape with a six months guarantee.
The other one has never been serviced, and shows no sign of needing one.
You mentioned that you were primarily a studio man. Perhaps you might give me a bit of advice. Last June I leased the ground floor of an old hotel (1500 square feet) with 14 foot ceilings, built quite a nice and roomy wet darkroom and still have lots of space, including a walled-in courtyard - 20 foot high concrete walls so no direct sunlight - that's wonderful for available light work.
Getting to my point here, I formed a co-op with four very good photographers to keep the rent share manageable, and they've contributed various gear, including fine Norman and Novatron studio lighting systems, but I'm damned if I can get the istDS to work with either. I bought the Wein Safe-Synch hotshoe adapter with the pc socket. With the Wein fitted to the camera's mount nothing happens, although the Wein will fire both systems when you press its test button. And, by placing a white 4X5 card in front of the pop-up flash I could get the systems to fire, but that's silly business.
I'm wondering if I'll have the same problem with the 10D I'm on the point of buying. They are now available in Tucson, Arizona.
Ted
