Home-made wireless P-TTL triggers?
We would need to know exactly what each pin on the body is sending to each pin on the flash, pin 1 may be sending the signal pin 3 needs??
It's late and Ive had a fair amount of beer
I was a dissapointed to find the built in wireless flash system didn't do this but hey ho there ya go
I have an "ishoot" radio trigger the receiver of which has a central pin and 4 smaller pins.
I've no idea what these pins do, but they fire off a Pentax 240AZ which has 3 pins (which match the centre pin and the 2 nearest smaller pins).
The transmitter portion (the bit that fits on the camera hot shoe) only has a single pin so can only react to a voltage presence/short.
On my K10D and a K5 the flash is fired sucessfully without any feedback.
BUT, and here's the crux, my sons camera which is a Canon when fitted with the transmitter will not fire the Pentax flash gun.
So it appears it is not simply a voltage sync but maybe a timing sync - does this make sense or help any?
regards
Bernard
Slovak
Member
Bratislava, Slovakia
I know wireless triggers have been discussed here on the forum before, but I haven't found exactly what I'm looking for.
Although I've had basically zero experience with wireless flash so far, I've been thinking and reading about it and it bothers me that there are virtually no wireless P-TTL flash triggers available for Pentax at the moment (ok, there are those Aokatec ones - but how long will the camera battery last if you fire a flash every time?) So I was thinking: would it be so difficult to modify p-ttl triggers designed for other brands? And if modified, do you think they would actually work? Like, there are i-ttl triggers for Nikon, for example. The pin layout looks VERY similar to Pentax flashes, but ok, there must be small differences and the pins of a Pentax flash probably wouldn't touch the pins on a Nikon receiver. BUT, what if I took a transmitter and receiver for Nikon and changed the hot-shoe for a Pentax one? Re-soldered it? Do you think it might work? Is there any special Pentax 'protocol', any sequence of signals, that might prevent this from working? My thinking is, if the number of pins is the same, what the heck does it matter what sequence of signals Nikon or Pentax uses? All that the transmitter does is send signals, and all that the receiver does is receive signals, right? So if I could achieve correct contact between the hot-shoe and the camera/flash, it should work, shouldn't it?
English is not my mother tongue, but I did my best to make myself clear and hope you understand what I mean
