Himalaya/Kunlun Mountains in IR
It was worth the wait. The distance from you to the horizon must be staggering, and the IR does seem to have cut through the haze as we hoped.
Lovely tones in no. 1. In no. 2 the wisps of cloud make it more mysterious, especially the curving one near the bottom.
I like the scale of no. 3, it is hard to actually work out the real size of those mountains, and there's a strong leading line - I like those! There's also a few bits of dust visible in the blank sky, that's pretty much unavoidable. What aperture was this one, the dust can be minimised by using fairly wide apertures.
No. 4 is a more classic view, again the scale and distance is overwhelming.
I have visions of a Boeing veering from side to side as aliengrove is trying to line up a shot
The first one was f5, second one f8, 3rd one f5.6, the last one f3.5.
Edit: just realised the first one was taken with the f3.5 135mm, as it shows no f stop on the exif. 2nd and 4t on the 50mm, 3rd on the 24mm.
Same for any other primes - once you've established a completely accurate infinity mark it is worth taping it in place.
The 35-105 is more difficult being a zoom, since the IR focus adjustment may be correct at 105 but off at 35. Having said that if it is parfocal in visible light it may be reasonably well-behaved in IR. One solution is to use masking tape on the ring and add an IR infinity mark for 35, 70, 105 after some test shots.
I can set the K20D up for that lens so you get AF confirmation, but again it may only be spot-on at one focal length. Likewise if I set up the sensor distance so the lens can be focussed via the viewfinder it may only be absolutely accurate at one focal length and may be useless for other lenses. Longer lenses are more demanding in terms of getting accurate IR focus. The K20D does have Live View and it does allow me to focus a 210mm lens fairly accurately, although the Live View is of poor image quality. There's too much depth of field to use Live View to focus a wide angle though, the image is very low res.
K.
Nigel
However I am not totally convinced that IR has been beneficial. In the high Himalayas the air is very clear, and pictures I took there with my trusty Super A (I think I did use a skylight filter) showed similar clarity on colour print film and slides.
At Limuru, near Nairobi, at dawn, it is sometimes possible to see Kilimanjaro to the South East, and Mount Kenya to the North East. The former is around 200 miles away, and the latter over 100. This is possible because the mountains are so much higher than the surrounding land. It's like seeing Manchester from London. Though rather more impressive!
Almost like illustrations. Numbers 3 and 4 are particulalry attention grabbing.
I would think you are pretty excited about the possibilties bearing in mind the locations you get to.
Looking forward to the next set.
Robert Adams
Ernst Hass
Beautiful photos, simply superb. I hope you give these ones a deserving A3 print at least somewhere!
Here,
there,
everywhere
These were taken with the Sigma 24mm Super-Wide II and my Pentax-A smc 50mm f1.4.
It's the first time I have tried processing them, too!
My Website
flickr
G+
Facebook
