High ISO Noise Reduction
Kevriano
Posted 06/12/2017 - 21:06 Link
Evening.
I'm curious to know how many of you use the built in High ISO NR on your camera, and if so do you have certain levels you use for each ISO?
If not, do you use a setting in PP that you prefer as it works better?
Personaly I use the lowest setting on anything up to 800, and theN in crease it above that, but I'm not so sure it doesn't actually add noise?
K3, K3 II, 100MM 2.8 Macro, Sigma 10-20 3.5, Sigma 17-50 2.8, Nikon D7500, Tamron 150 600 G2
Mike-P
Posted 06/12/2017 - 21:24 Link
Always switch it off as I prefer to do it in PP. That way I can apply NR to say the background but not to the main subject which may need the detail (even if it is noisy)
i-Berg
Posted 07/12/2017 - 00:44 Link
Ditto - apply it where and when you want that way.
swarf
Posted 07/12/2017 - 09:08 Link
Ditto - except that I mainly use the Nik plugin 'Define'.
Phil
My Flikr Page link
