helicoid extension tube
davem
Posted 03/01/2014 - 11:41 Link
I have seen a helicoid extension tube on ebay and wondered what is it and what does it do?
Can anybody help?
Dave
bforbes
Posted 03/01/2014 - 11:47 Link
Helicoil inserts are used to repair or strengthen threads in "soft" materials. link
Algernon
Posted 03/01/2014 - 11:53 Link
A helicopter is a type of rotorcraft in which lift and thrust are supplied by rotors.
http://en.wikipedia.org/wiki/Helicopter
Edited by Algernon: 03/01/2014 - 11:53
Algernon
Posted 03/01/2014 - 11:56 Link
Can anybody help?
Dave
Best variable extension tube ever. Length varies as you twist it.
Good for slide copying etc. The Pentax Slide Copier K actually
has one built in.
Edited by Algernon: 03/01/2014 - 11:58
pentaxian450
Posted 03/01/2014 - 12:48 Link
Are you drunk again?
Algernon
Posted 03/01/2014 - 13:03 Link
Barrie's been hacked
jamieallan
Posted 03/01/2014 - 14:18 Link
Can anybody help?
Dave
Dave,
This might help
http://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&ved=0CD8QFjAD&u...
Funnily enough I've been looking at the same. The helicoid is effectively the screw thread that allows the two parts of the tube to expand/contract in length with a high degree of tolerance and no light leakage I'd suspect.
Jamie
Edited by jamieallan: 03/01/2014 - 14:21
Algernon
Posted 03/01/2014 - 14:47 Link
Shown here.....
http://www.bdimitrov.de/kmp/misc/macro/ext_helicoid.jpg
They usually go for £50 - £100...... Very handy piece of kit.
I bought mine new from Park Cameras in the 80's
davem
Posted 03/01/2014 - 23:09 Link
These look interesting. The only ones I can see at the moment are m42. As you say Algi there is a k and I think an m. presumably the M42 is completely manual whereas the k and m will allow the aperture to be set.
What do you think that the best lens would be in conjunction with one of these and the K5?
Dave
jamieallan
Posted 03/01/2014 - 23:25 Link
Dave
Dave,
The M42 is a completely different lens mount so unless you buy a K to M42 adaptor and an M42 to K adaptor these will not work. You will not be able to fit your extension tubes to your K series camera and you wont be able to fit your k series lens to the extension tubes.
Jamie
petrochemist
Posted 04/01/2014 - 08:51 Link
Unfortunately nobody seems to make an adapter to mount k bayonet lenses on m42 threads. Mounting m42 to PK is very common and has been done since the k mount first came out, so if you have some m42 lenses it's a great device for macro. M42 helicoids are cheap and easily available in a range of different lengths, K mount ones are rather rare
Algernon
Posted 04/01/2014 - 10:27 Link
Dave
Non of the Pentax K Tubes have 'A' contacts. I've never found that a problem with the Helicoid because I normally use it on mash-ups where a full sized tube won't work, such as slide copying etc. Sometimes the lens is reversed so the contacts wouldn't work anyway.
Olympus also did one and they sell for a lot more than the Pentax ones.
A K bayonet lens to M42 adapter can be cobbled up from an extension tube and an M42 T2 mount.
Peter Elgar
Posted 04/01/2014 - 11:16 Link
years ago I WON a Asahi Pentax Helicoid Extension tube in ' Pentax Club Magazine' when it was run by Ron Spillman -- had £25-00 of Pentax gear of my choice so I got that and some pentax Club filters for my £25-00 prize.
gartmore
Posted 04/01/2014 - 11:41 Link
I got an M42 one on ebay to use as a focussing mechanism for an old lens mounted to the Q, I think it was about £15 and remarkably well engineered
davem
Posted 04/01/2014 - 19:41 Link
Thanks everyone, especially Barry for being so quick off the mark
Please bear with me whilst I sum up my options
1. Use an M42 lens with M42 helicoid tube and mount the assembly onto any k mount camera (including the K5) using an M42 k mount adaptor. Set the aperture on the lens
2. use the above on the Q with an additional adaptor for mounting k lens to the camera. Set the aperture on the lens.
3. Use an old k lens with an M42 T mount to connect to the helicoid. Mount the assembly onto the camera using an M42 k mount adaptor
Have I got it right or am I missing something.
Don't you just love working these things out.
Sometimes I think that pentax or a third party should reintroduce helicoids, extension tubes,bellows etc. as it would make life easier
Dave
