Greetings how is life in the realm of Pentax?
Posted 11/08/2017 - 23:56
Posted 11/08/2017 - 23:59
Hi. Look forward to hearing of your experiences and seeing some of your photos. Which lenses do you like for your K-1?
Posted 12/08/2017 - 00:10
JAK. D 150-450mm, 28-200mm (from 35mm film Pentax), 28mm f2.8 prime with 2x teleconverter, 20-40 ltd (aps-c mode), 85mm f1.4, and a few others mostly from 35mm film Pentax cameras Tamron, Vivitar, Formula 5, and Sigma. I do have the 50-500 sigma PK mount but since i purchased the 150-450 i rarely use it.
I was planing on a new Pentax D 24-70 but i do not care for its image quality.
I am curious as to the rumored D 50mm.
Posted 12/08/2017 - 00:18
Thanks, good selection there! If you're not keen on the 24-70 have you considered the 28-105? If nothing else it's a bit cheaper!
Posted 12/08/2017 - 00:21
I believe i have a 28-105mm, will have to make an effort to test it out.
Flea markets and garage sales boxes of lenses to rummage through. Why do i do this to myself?
Posted 12/08/2017 - 00:32
There's several incarnations of that. the latest being the DFA28-105 which came out at about the same time as the 24-70. Others go back to film camera lenses which aren't too bad but the DFA is fine. Another, if you have one or come across one is the FA24-90, the last zoom of the film era before the istD came out. While plastic construction, optically it's pretty good.
Posted 12/08/2017 - 00:37
I will look into that, thank you.
Posted 12/08/2017 - 08:01
Hi there great to have you around,, hope you will share some of your efforts with the K1..
Stuart..
Stuart..
Posted 12/08/2017 - 15:37
Indeed. The quest to contribute to the commonwealth of Pentax knowledge and wisdom.
I also use a Pentax K200d. Helps keep the skills honed.
dovah
Member
Before one inquires yes my name is short for dovahkiin.
