godox flash
John
thanks John. I tried that when i first had the flashgun but it did not work. logically it must be something on my K5 as the gun works on other cameras. I have just spent 10 minutes fiddling with settings on the flash unit and it then started working.
Like I said on original post, it is odd.
old lens
Member
hampshire
got an odd problem with my k5 camera when using a flash gun. I purchased a Godox V860iii gun and it will only work after messing around with the settings, it takes a while and will eventually fire up. I then purchase a Pentax AF540FGZii gun and it works perfectly. This is when it gets weird!
A friends Pentax Kp camera works fine with the Godox gun and then i put the Godox back onto my K5....and it works staight away! Try the Godox on my K5 a few weeks later and.. does not work again.
any thoughts please?
regards
Rick
