FS: Tokina AF 20-35 f3.5-4.5 - Excellent
Any pics would be welcome to see the beast!
Gareth
My outfit: K1 gripped - K3ii - two Z-1P - Pentax D FA 24-70mm - Sigma 70-200mm OS HSM - Pentax modified DA* 60-250mm f4 - Irix 15mm Firefly - Pentax FA 35mm - FA 50mm - Sigma EX 20mm - FA 28-70mm f4 - Tamron SP 90mm macro - Pentax AF 540 FGZ II
Is this the ATX version, MK1 or MK2? Asking as reading the reviews it says the earlier versions had a rotating front element and the later didn't!
It's not the AT-X (that's the f2.8 model that has the larger filter size, is heavier and IMO softer at wide apertures) - this is the slightly more compact Mk1 AF model with the rotating front element. I know that seems like a problem for filters (grads especially) but in practice using a filter holder on this or the Pentax FA 20-35 isn't easy and depending on the holder type you can get vignetting. With these and even my prime 20's and 24's I go back to holding the filter in front of the lens once the composition is set up.
I'll try to put some photos up tomorrow Gareth
That's old tech for you
AKA Welshwizard/PWynneJ
Member
Worcestershire
It is better built than the Pentax and has a faster maximum aperture (although the Pentax has a constant aperture) - IQ is pretty good, I'd say the Pentax edges it slightly but there's not a lot in it. I have a wide angle metal lens hood with it (not an original) which is very good but does vignette very slightly at the widest setting.
condition is very good and reviews are quite positive....
https://www.pentaxforums.com/userreviews/tokina-20-35mm-35-45.html
I'll put some photos up in the next couple of days
£149 inc. P&P (RMSD)
UK Only, Bank Transfer, Cheque (cleared), PayPal (Gift), Postal Order or Cash on collection, Inspection Welcome
