FS: Pentax 70mm Limited
Posted 24/11/2016 - 11:42
don`t believe it is FF compatible same as other da Limited lenses.
Cheers,
Bruce
Bruce
Posted 24/11/2016 - 11:46
According to RiceHigh it is. I have used the 40 Ltd and 50mm 1.8 recently on film without any problems.
See here for more info:
http://ricehigh.blogspot.com/2009/10/compatibility-of-da-lenses-on-full.html
Posted 24/11/2016 - 12:11
This is incorrect. A few DA lenses are full frame. Many work well with minor vignetting and/or detail loss in corners. And some are not usable full frame, notably many zooms and wider primes. There is plenty of information around which is which. don`t believe it is FF compatible same as other da Limited lenses.
The DA70 should do quite well full frame with some fall off and detail loss in the corners.
Nice lens with very nice colours. Good luck with the sale.
Posted 24/11/2016 - 13:30
It's not an 'officially fully supported by Pentax' full frame lens for which Pentax provide lens correction support for it in full frame mode as they do for the FA 77mm Ltd. It does however cover the full frame image perfectly well though.
I had this lens and it worked well on my K1. If there was any vignetting it was not not noticeable. I sold it to buy another lens which would be of greater use to me but this lens is a gem if you want that focal length.
Miles
Posted 05/01/2017 - 17:43
Still available at a very reasonable £220 plus £8.55 RMSD
Posted 07/01/2017 - 14:47
Now £200 plus RMSD at £8.55
Cambridge
£220 plus £8.55 RMSD.
